http://www.popularhotrodding.com/tech/0610phr_cylinder_head_porting/photo_03.html
That pic is a good description of what i'm talking about. Hope the link works. Was that what you had done to your bike head? It makes sense that the same thing should be done on both the valve and the valve seat though.
Edited to add: In serbian language, the distinction between a valve cut and a valve seat cut is a bit confusing, so i can't be sure how it would translate to english, but it makes sense that both parts are cut to increase the contact area.
EDIT2: Okay, i read up a little to refresh my memory on english terms
The valve seats are said to be "cut" and the actual valves are said to be "back cut". You can actually do a 3 angle valve seat cut without back-cutting the valve. What i'd like to do is back-cut the valves as well as the valve seats.
So a better form of my question in the first place would be "how many angles are fiat 8v and 16v engines cut to, and are the valves back cut to 2 angles (99.99% that they're not).
This is what a back cut looks like:
http://www.carcraft.com/techarticles/116_0612_valve_angle/photo_02.html
Double back cut:
http://www.carcraft.com/techarticles/116_0612_valve_angle/photo_11.html
Double back cuts are rare though, as far as i know. But single back cuts are said to increase the flow a lot, and since i'm thinking about swapping a 16v engine into my mpi sei, and then turboing it, i want the most flow i can get out of it.
Sorry for the misunderstanding, i'm still learning the english terms for all these tech things
