My fan has been hardwired to always on with the ignition this has been done by wedging a small jump wire into the plug.
I've looked everywhere and can't find where this jumpered plug should be plugged into (once alien wire is removed) but I do have three mystery wires hanging down just to the right of the engine block there's a spade connector and from fist glance two snipped cables but no plug - I also have a three pin plug that's lingering further over to the right similar in appearance to the ECU diag port but without a rubber cover. (it's not the ecu port as I can see that this one is lower down)
Any ideas what's going on?
With the fan disconnected the engine warms up as expected. As far as I can tell thermostat is fine, water pump is fine so can't work out why this has been done.
Where the fan has been running all the time it's rough as nails now and sounds like the bearing has gone (it sounds like rattly grinding metal ) will the fan from a 900cc fit a sporting? Are they the same?
I also need to replace the rad - it sprung a leak the other night (after discovering the above) I'll be getting a replacement from my local motor factors later today, can't afford to wait any much longer without a rad!
I love Fiat cars - just wish they'd give me a chance now and then
