Having had the radiator replaced and my 1.1 Sporting working fine for two months, suddenly the temperature has started increasing for no apparent reason. No problem with a water leak - the reservoir is full. Water pump is working fine.
When on a long journey yeasterday suddenly the temperature went up dramatically and I just had enough time to get off the motorway before it reached red (although subsequently it hit the mark )
When I checked the radiator it was cold and afterwards the water reservoir was empty (although there wasn't a pool of water under the car when I stopped).
Having limped to the nearest town, I found a local mechanic who checked the thermostat (which had apparently been removed ). In any case, he said it didn't seem to be the problem.
They revved the car and as the temperature was increasing he could see some white/blue emissions from the exhaust. We had already checked the oil access point and the oil itself and it showed no sign of being being contaminated, ruling out a head gasket problem.
He opened the reservoir and the water gushed out but was cold. He said the problem was the cylinder head.
Does this sound right? Having had problems with wrong diagnosis' before, am a bit sceptical. He said it could be repaired but the cost would be at least 600 pounds or more.
Up to the point of overheating the car was working perfectly although I did notice a bit of sluggishness on the journey. Could this be the symptom of "something waiting to happen"? As the car has had a few temperature problems during the past year (due to bad diagnosis' and crap mechanics here in Spain) could this have been the final straw?
Having paid over 900 euros in repairs in August, is it worth paying 600 pounds (or euro equivalent) to repair it again - can the cylinder head be repaired or should it be replaced? The car is 1998 "R" reg with only 91k on the clock. It should have plenty of life left yet.
Any advice would be appreciated on diagnosis etc
Many thanks!
Many thanks!
