Anyone know what sort of current a Sciento heater fan draws?
My mates is busted, the fan doesn't spin and they are getting cold on the commute.
I've tested all the usual things; switch, fuse, fuse board. maxi fuses and I still can't make it work.
If I put current directly to the fan motor it does work.
I'm thinking the best course of action is a rotary switch, in line fuse and wire to the batt/fan.
So I need to make sure a get a switch that doesn't burn out.
Any thoughts?
Any thoughts?
