Styling which is easier...
Off set for a cinq S is 27.5, but fiat put 3mm spacers on the cinq sporting whichs gives ET30.5
So if you take away the 3 mm spacers, u will have something really close to et 28.
Ming
Ming
My guess is the 28s will just fit. For best handling, 3mm spacers (get some off a Sporting in a scrappy or cheap enough from FIAT) on the front only.
mine is a sporting... but esentially if i cant find the wheels i like in et30ish then i could run the et28s without spacers is what your saying yes?
something which used to confuse the hell outta me with offsets is that you have to take the wheel width into concideration
Depends what you're wanting to do, in terms of chassis dynamics keeping the same offset or running slightly smaller offsets is the way to go, this doesn't require much working out besides adding the right spacers. Unfortunately keeping the standard ET usually results in wheel/body work interaction. You can either adjust the offset (imo the 'bodge' method, however it is simple and relatively cheap) or you modify the body work (the 'correct' method but usually involves a fair amount of cash to sort out)
