Technical Drivers door not fully unlocking with central locking
Ian S
Eastern London / West Ess
Hi all, I just bought a cinq 1.1 sporting. R reg.
I did a search but couldn't get this forums search engine to look for phrases. It found every thread containing the word door.
So I'm having to ask....
There is a problem with the drivers door lock. The central locking doesn't fully un-lock it and sometimes it locks again.
I have to turn the key hard over to make it unlock.
Do you know why?
What's the cure?
Thanks.
Noticed this eve that a small turn of the key in the drivers door operates the central locking which pops up the locks, but they bounce a bit, and this seems to lock it again. So then the key has to go all the way around.
I would already have taken the door card off but it seems to be breaking apart before it moves.
Do you know why?
What's the cure?
Thanks.
The door lock motor drives a screw thread to push/pull the lock mech.
As the actuator moves, A set of wiper type contacts slide up a pcb and give power to the motor.
If the wipers are dirty/damaged, Then the motor will stop before reaching the end of it's cycle.
There are two more wipers for control module trigger which activate one of two relays, Up/Down. (hence 4 wire system).
If any motor stops at any point between rest then the other that HAS moved will be signaled to move back.
Motors that are worn/loose/incorrectly fitted can bounce and trigger a move back command.
The door lock manualy lifts the motor actuator and triggers an open/close command to the control module.
Hope this helps in problem solving. :idea:
