- Aug 23, 2007
- 551
- 93
okay, so i want to install an ignition cutoff switch, a fuel pump cutoff switch, and a starter button. I've seen this one asked before, but i didn't really see the information i needed there, so i'm starting a new one.
I think i can just go and wire the fuel cutoff switch in series with the inertia fuel cutoff switch, so either one of them would cut off the fuel (sounds like a safe idea)
However, i'm a bit puzzled with what to do with the ignition and starter leads. First off, can i just cut the wires at the ignition barrel and put a switch in parallel (or in series) with those? Putting the ignition switch in series with the existing one makes sense, as the key needs to be near the ignition barrel, so the ecu can read the code off the key (if i have that right), and it will keep the thiefs away.
Rallycinq wrote this (in 2004.):
Thanks in advance! :worship:
What does that mean exactly, and does it apply to seis?A push button should be ok on its own. Fitting a cut out and ignition switch is a bit more tricky as the ignition will feed from the parking light circuit even when he ignition is switched off.
