The FIAT Forum
Old 15-07-2008   #1
Trader Rating: (0)
clutch pedal
hi,when i press the clutch pedal on sport sei it has very little feeling to it,the biting point is pretty low and sometimes engaging gears is difficult.
is there any way it can be adjusted or is it on it's way out.cheers
needspeed is offline
Old 15-07-2008   #2
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
rallycinq has donated! New Caledonia
Re: clutch pedal
Yup, it can be adjusted at the gearbox end.
D
rallycinq is offline
Old 15-07-2008   #3
Trader Rating: (0)
Re: clutch pedal
hi,any ideas how i do this.is it an easy job.cheers
Old 16-07-2008   #4
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Re: clutch pedal
Very easy job. I've described it so many times here I'm not going to do again. The search engine should find it, or it's in the Haynes.
Wanted: Forged low comp 1100 pistons.
fingers99 is offline
Old 16-07-2008   #5
Trader Rating: (0)
Re: clutch pedal
On mine theres a white plastic bolt at the end of the cable, you can turn this (by hand) either way to adjust the clutch, you should see the pedal rising and falling.
It could still be on its way out mind, even after adjustment, but its the cheaper option to try first.
There are no sheep in the city....
Rosso83 is offline
Old 17-07-2008   #6
I hate scooters...
ronnieronson's Avatar
Trader Rating: (0)
ronnieronson has donated! United Kingdom
Re: clutch pedal
...and on a side note:
"Turn right for height, and left to lower"
ronnieronson is offline
Old 17-07-2008   #7
Trader Rating: (0)
Re: clutch pedal
cheers guy, had alook today and adjusted clutch.feels alot better now
vB code is On
Clutch Pedal davscer Cinq/Sei > Technical 4 19-05-2008 01:55
Wanted: clutch pedal assembly, clutch fork (FIAT Seicento Parts Wanted) tjaartjacq For Sale / Wanted 0 16-04-2008 06:25
Clutch pedal mentalkim Cinquecento / Seicento 3 06-07-2007 00:29
Clutch pedal The younger modder Cinq/Sei > Technical 2 22-03-2004 03:43
Clutch pedal. stiloactive Stilo > Technical 8 21-03-2004 07:17
