The FIAT Forum
Old 15-07-2008   #1
Trader Rating: (0)
Inertia switch no power
I have Seicento 1108 sporting T reg . car started then cut out thought i was out of petrol i was low so put £10 in and tried to start car but would not start up .
so checked to see if there was a feed to the carb nothing , then checked inertia switch and i have no live feed from it , the car was running yesterday checked all fuses that i could see , all ok . any ideas anyone
larsson1971 is offline
Old 15-07-2008   #2
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
Re: Inertia switch no power
it doesnt have a live feed, it deals with the negative side of things.
when u turn the ignition on, do you hear the pump prime for 2 seconds or so?
arc is offline
Old 15-07-2008   #3
Trader Rating: (0)
No nothing
Old 15-07-2008   #4
arc
arc's Avatar
Trader Rating: (0)
ok, check the 10A fuse near the ECU. If that is ok, then i would start fault finding on the fuel pump wiring.
bung a multimeter accross the fuel pump connections and get someone to turn the ignition on. the pump is under the rear seats. lift them, and there are 4 nuts holding a metal place in place - its under there. one set of wires is for the gauge, the other for the pump.
if power is getting to there, its safe to assume the pump is dead - but u may wanna try running a 12v feed to it just to make sure
arc is offline
Old 15-07-2008   #5
Trader Rating: (0)
checked 10 amp fuse ok
had the panel off at the rear seat/tank
put a test light in at the 4 wires at the fuel pump
one wire is live
another is live but dim
and the other 2 wres have nothing
anyone know the color for the pump feed
as checked the 2 wires at the inertia switch under the dash but nothing from these
as assuming there got to be fedd to control the pump
so still reckon no power so dont want to condemn thepump yet
got a power probe but need the correct wire at the pump to feed to see if the pump is working or not
fiats how true
Fix
It
Again
Tony
thanx
Old 15-07-2008   #6
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Originally Posted by larsson1971 View Post
fiats how true
Fix
It
Again
Tony
you want help or not
T14086 is offline
Old 15-07-2008   #7
Trader Rating: (0)
Of course this is the best forum there is ,
Old 15-07-2008   #8
Trader Rating: (0)
anyone know the color for the pump feed .
Old 15-07-2008   #9
arc
arc's Avatar
Trader Rating: (0)
green and black should be live to the pump.
black and purple should be the return.
you wont get much on the green and black though, unless the engine is turning over or the ignition has just been switched on.
use a multimeter to check that there is a connection from black/purple to ground.
arc is offline
Old 15-07-2008   #10
Trader Rating: (0)
Cheers ARC will try that . let you know
Old 15-07-2008   #11
Maze's Avatar
Trader Rating: (0)
Egypt
hi ;
i think there is 2 big wires and 2 thin wires the 2 big are the feed of the pump and the 2 thin are the level of fuel , put the test lamp on the 2 big wires then turn the contact on the lamp must be light.
Maze is offline
Old 15-07-2008   #12
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
rallycinq has donated! New Caledonia
The pump wires go to the pump, the gauge and light wires go to the sender unit.
D
rallycinq is offline
Old 15-07-2008   #13
Trader Rating: (0)
car was running fine yesterday came out today tried to start and that is it .
fun and games
Old 15-07-2008   #14
Trader Rating: (0)
one wire is live....bright may be fuel sender
other is live but dim may be pump
other two nothing earths
had lines of at inlet (carb/singlepoint)
so when cranked over had no fuel coming out
still no feed at the inertia switch
so if this has no feed it will not feed the pump as inertia is master control for safety so reckon fault is feed to the Inertia switch
unless this only has power when vehicle is running dunno
so is this down to
ecu at fault
fuel pump relay at fault
Old 15-07-2008   #15
rallycinq's Avatar
Trader Rating: (1)
Supply to pump, then to earth via crash switch.
Does your car have an immobiliser?
D
vB code is On
SW Stilo Rear door handle switch operates as rear glass switch darko123 Stilo 6 15-01-2008 13:03
Power through Ignition Switch - Help! oneiro Punto 1 27-01-2007 03:45
switch. cm246 Cinq/Sei > Technical 1 17-10-2005 21:36
inertia switch asbit Punto > Technical 1 02-09-2005 17:25
Engine Under Power When Switch On Air-cond simonyap Bravo / Brava 0 22-04-2005 08:19
