The FIAT Forum
Old 15-07-2008   #16
Trader Rating: (0)
Re: Inertia switch no power
just the factory one
will double check the wires 2moro and once sure will power probe it see if pump works
let you know how i get on
as if the dim light is the pump feed may just be the pump has gave up the ghost
so new pump required
but if the pump does work
let the ganes commenceouch
larsson1971 is offline
Old 15-07-2008   #17
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
there is no feed to the inertia switch, it cuts out the negative connection. poking it with a test lamp is going to show you nada. get a multimeter, they're only about £2.99 from maplin. use that to check that the test the systems properly
as i've already said, the fuel pump will have power when the ignition is inititally switched on - or if the engine is running.
try this, disconnect the two pin plug from the fuel pump. with the green/black (sometimes orange) and purple/black. connect the test lamp across them, then watch the lamp as you turn the ignition on.
arc is offline
Old 16-07-2008   #18
Trader Rating: (0)
got multimeter
will try that & report back
Old 16-07-2008   #19
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
rallycinq has donated! New Caledonia
Originally Posted by arc View Post
it doesnt have a live feed, it deals with the negative side of things.
when u turn the ignition on, do you hear the pump prime for 2 seconds or so?
Originally Posted by larsson1971 View Post
No nothing
Check the immobiliser is doing its thing correctly and also the fuel relay. I have rarely seen a pump fail.
PD
rallycinq is online now
Old 16-07-2008   #20
Trader Rating: (0)
when meter is connected and turn on ignition i get power then goes to zero
when i proceed to cranking over the engine i get a feed as well and when i let the key off the cranking posistion the feed stops which should be normal
so got power
took the pump/sender out of the tank and away from the car and used the power probe to see if pump would work
which it did
checked the wires that run the pump for continuity thats are located internally and all is fine there as as well
so put it back into the tank and tried again
nothing took the seal and plastic off the multiplug plugged it done the ignition and cranking and motor was working
at this time i had the feed and return fuel lines off but when the pump was working it never spurted out fuel
put the multiplug back together and nothing again
so got the two parts of the plug which is working the pump but still no fuel
so now i dont know if the pump is weak and cannot prime up
or something that i am missing
the saga continues
Old 16-07-2008   #21
Trader Rating: (0)
Pump working ok , had the pump out and the small filter had taken some bum fluff cleaned that , but the problem lay down to a faulty plug that powers the pump . cheers guys for all the info and help.
vB code is On
SW Stilo Rear door handle switch operates as rear glass switch darko123 Stilo 6 15-01-2008 13:03
Power through Ignition Switch - Help! oneiro Punto 1 27-01-2007 03:45
switch. cm246 Cinq/Sei > Technical 1 17-10-2005 21:36
inertia switch asbit Punto > Technical 1 02-09-2005 17:25
Engine Under Power When Switch On Air-cond simonyap Bravo / Brava 0 22-04-2005 08:19
