| rear wiper hi, got mot tomorrow and was wondering if the rear wiper was part of it because mine don't work. will this mean it will fail.cheers
| Re: rear wiper as far as i know, the rear wiper is optional. but im unsure that if its fitted it has to work? If you cant fix it I would just remove the arm all together. ![]()
__________________ Craigs Cinq project 1242 Blog + restoration | |||
| | #3 | ||
| Get a wriggle on! | Re: rear wiper not a testable item, along with the spare wheel | ||
| | #5 | ||
| Re: rear wiper cheers guys ![]()
| | #6 | ||
| Re: rear wiper you should be ok , not a tested item
| | #7 | ||
| Smutdar as Standard | Re: rear wiper mine seized a while back... easy enough to fix, just removed the motor, drilled a tiny hole in it and squirted some WD40 in it. the "park"sensor has gone from it now but that doesn't matter.
__________________ | ||
| Rear Wiper | R12MUS | Punto | 1 | 23-03-2008 13:27 |
| rear wiper | carlos1981 | Punto > Technical | 7 | 01-04-2006 22:16 |
| For Sale: Mk1 punto front , and rear wiper motors , plus rear wiper (Miscellaneous) | gezzauk | For Sale / Wanted | 0 | 06-03-2006 22:55 |
| New rear wiper?? | AppleSei | Cinquecento / Seicento | 10 | 23-01-2006 18:00 |
| Rear Wiper switch operating to the rear window heater | danielson81 | Cinq/Sei > Technical | 2 | 11-10-2005 22:33 |
