I like that idea of useing the punto 75 cam i will need to check out the opening duration for the exhaust and inlet to chek it does not lead to over fueling or cause rough running
Sounds like you have problems. I've used P75 cams in 1.2 & 1.1 SPIs with a 40mm TB and a GSR F1i induction kit, the latter having a large bore exhaust. My current 1108cc MPI also runs a P75 cam but only has an induction kit. All were remapped to some extent.
All 3 easily pull away in 2nd at 1000~1250 rpm & the 1.1 SPI had 195/45R15 rubber. All 3 also were fine at idle in 1st gear.
The 1.2 got going a little above 2800 and tailled off after 6300ish
The 1.1 SPI started to pull hard from around 3250 till the 6600 to 6750 mark
The 1.1 MPI kicked in around 3000 rpm and becomes breathless around 6200, it feels eager like it wants to rev on so maybe the exhaust and/or throttle body is restricting it.
You're using a P75 manifold wet? That's gonna cause problems at low rpm, well any low airflow conditions really.should of mentioned im using the punto 75 head and manifold. with spi. the porting on the punto 75 head is somewhat larger then the other heads so that might be the reason.
I recon its worth it as it saves farting about with shims
Are you nuts?
1. I'd point out that what you've done clearly doesn't work.
2. Doing the shims is easier, quicker and cheaper than bodging an SPI mani onto an MPI head. It's a couple of hours work, nothing more. You need nothing more than a set of feeler guages and a torque wrench (a calculator helps).
3. Checking the valve clearances (and fitting different shims) should be a routine (albeit infrequent) part of maintenance.
fitting a spi manifold to a mpi does work... theres no reason it wont!
craigb244 said:things ive noticed with the p75 cam is...
* Alot less bottom end! {In very slow moving traffic I used to be able to leave the engine at idle and slip the clutch to pull me along. now it just stubles and hops (imagine it would be even worse on a 1.1). this I expected}
I rest my case. Seems that something -- and I'd guess the match of the SPI inlet mani (the Uno 45 one is generally though to be better, anyway) to the MPI head.
Does sound a bit like traditional petrol pooling.
But we know that the straightforward fitting of a P75 cam to an SPI (or MPI) head and inlet mani works just fine -- no loss of bottom end.
What are these bikes? Even on the old Desmo Ducatis we used to leave it 1500 to 2000 miles!
Ok just so i have got this straight in my own mind i can take a standard 1108 spi engine and so long as the shims and the tolerances for the top end are ok then a standard punto 75 cam shaft can be fitted and not cause any detramental effect to the day to day running of the engine. When i do get arround to doing this i will probaly port and polish the cylinder head for a better flow and go for a 4-2-1 exhaust manifold currentley it has an old conical shap piper cross induction filter and an Eco-teck cb26p valve fitted.
