Technical Advice wanted urgently
mickyp
Hi all. I am new to the forum. I am thinking of buying a Fiat Seicento Mia. It is a 1999 on a T plate, 60,000, 899cc. I went to see it today and i immediately saw an oil leak at the top of the engine. Looks like a gasket leak but not knowing where a head gasket is on these cars i do not know if it leaking from there. I also took off the oil cap and there was a bit of gunk. I was told this might be cause the car is only ised for short runs.There was no oil in the engine itself but i am just wondering if it worth buying or should i steer clear. The guy had it up for £725 but said he would take £650.
Advice or pictures of a head gasket leak. I have looked through the forum and it looks like the rocker cover but i am not 100% sure.
Thanks in advance for any help.
It'll be the rocker cover gasket if the leak is above the exhaust manifold.
Check the dipstick for mayo.
Get a test drive. Beware if the clutch bite is high. Make sure the radiator fan comes on. Look for any rust in the boot -- if there is, walk away.
650 is a bit much for an 889. Try for 600.
Thanks for all the advice does anyone have any pics or a more detailed description of rocker gasket?
