The FIAT Forum
Old 11-06-2008   #1
Trader Rating: (0)
jamiewilson has donated!
Yes more rear bush hassles!!!
Yes i'm another one sticking powerflex's in, but my main trouble is i cant even get the arm off! I've tried for the past 3 evenings with putting plusgas and wd40 on the bolts, both sides, but absolutly nothing!
Just checking, is the nut welded to the arm and then you should just undo the bolt from the other side?
I'm starting to consider putting the rest of it back together and leaving it, cant really afford to pay someone to fit them. Anyone fancy heading up to my driveway and giving it a tug? ...free beer! lol
Jamie
jamiewilson is offline
Old 11-06-2008   #2
umop apisdn
balidey's Avatar
Trader Rating: (1)
balidey has donated! United Kingdom
Re: Yes more rear bush hassles!!!
Yes, but I managed to 'undo' the nut with a long breaker bar and this took care of the weld
Your sister is hot, but your mum does that thing with her tongue
balidey is offline
Old 11-06-2008   #3
Trader Rating: (3)
First off WD40 will get you almost no were, you need proper penetrating oil, drown the nuts in the stuff the day before then unbolt the bolt not the nut.
I used a long arm 1/2" drive ratchet with decent sockets & the bolts were very hot to handle straight after they came out.
GoBe is offline
Old 11-06-2008   #4
Trader Rating: (0)
a source of heat is what you want... i purchased a small gas blow torch some time ago, handy little tool
jimboy is offline
Old 11-06-2008   #5
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Of which bolt and nut do you talk?
The two bolts which hold the arm on have nylock bolts -- they are not welded on (at least, on later cars) -- you can't weld nylocks cos the nylon melts!
The shocker nuts are welded on: the trick is to counterhold the nut, while going at the bolt. If the bolt is seized on to the sleeve, the shock is probably scrap.
For the big bolts holding the arm on, 2 breaker bars (or some scaffold tube over the wrenches) will almost always do it. Failing that, the heat spanner always does it.
Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity!
fingers99 is online now
Old 12-06-2008   #6
Trader Rating: (0)
Got it!!! Soaked it again in plusgas then managed to find a nice big pole to use as a breaker bar and finally i heard the crack as the bolt released! The bolts are nylocks not welded, will have to go and find some new ones now!
Thanks guys
Jamie
(T) rear shock top bush antsuno2 Uno 15 09-09-2008 14:08
(T) Rear Suspension Arm Bush Death Cinquecento / Seicento 10 25-11-2007 17:40
(T) rear bush removal tips levemir Cinquecento / Seicento 11 26-03-2007 17:48
Boneless Bush Dobby Leisure Lounge 1 10-09-2006 02:16
(T) Rear bush problem Poll LanciaMad Cinquecento / Seicento 22 16-02-2006 21:25
