- Jun 28, 2006
- 719
- 123
I've heard people say that the Eibach springs are the best money can buy, my Mk2 Sei came with Eibach springs on, I also had a set on Weitec -40mm springs in the garage. With Eibach springs showing signs of 'cento lean & the car looking a little to high for my liking I decided to install the Weitech springs to see how things would work out.
Firstly, the Weitec are firmer, they're far from bone shakingly firm but you feel a lot more of the lumps and bumps in the road, with the Spax dampers ride quality is still much improved over the the fiat items. The trade off however is lower levels of body roll. This also means that there's more pressure on the inside wheel letting you get on the power earlier &/or harder without it spinning up.
The road between my house and the motorway has a lot of camber changes & ridges at odd angles across the road, the Eibach springs tended to let the car 'drop' over the ridges causing some weird reactions from the chassis, with the Weitec springs each wheel is 'put back down' making the whole sensation less unnerving at higher speeds. I've also found the rear of the car feels far more certain.
There is more feedback from the steering with the Weitec springs, along with a little more kick from larger bumps in the road surface & a touch more low-speed weight to the steering. Turn in is a little slower, more than corrected for with an additional 6mm of spacers, but mid-corner grip is increased.
All in all I'd recommend both of these springs to anyone. Both deliver handling advantages over the standard fiat item. The Eibach delivers a more supple ride but sacrifices handling to do it, the Weitec springs handle better but lack the ride quality of the other springs.
