General seicento heater probs
jock350
own a 2000 sporting,heater in car only blows hot air,uses no coolant,new thermostat,and bled the system still only hot air comes out any ideas,thanks
id check all the tubes for blockages, flush the coolant out and check all tubes, remember to bleed the system when replacing the coolant (50/50).
hope this helps buddy (y)
I cannot help with the problem but i just thought i should say that this had me lauhing out loud!
Anyone else noticed the distinct increase in cock trouble?
Pretty soon it will be up there with clutch cables and handbrake cables as the problem areas
What can I say? :confused:
Cock really is the correct name for it: it's a valve (same kind of thing as a central heating radiator valve) that controls the water flow through your heater matrix. So, somewhere near that, under the soundproofing in the engine bay. Rallycinq will give you a more precise location, no doubt...........
Oh, the temptation, but no, I will resist, its behind the carpet on the bulkhead as as suggested.
Gormless Cretin
found my cock it wasnt stiff,just cable fell off,thanks to all you with cock problems,dont let a stuck cock get you down
