| | #31 | ||||||
| Principality Retained :) | Re: bike engined Seicento Most. Im beginning to think gear actuation sounds like a PITA - currently thinking some form of electrical actuator there. Plus cramming heat management gear into a useful space (with adequate vent air) also looks hard!
__________________ Tom (AofB) ![]()
| | #32 | |||
| custodian of imola blue | Re: bike engined Seicento
For heat management, rad up front, water by copper/aluminium pipes. For intercooler/oil cooler, (well meshed) duct to exit through Abarth rear bumper (one of the Novitec cars seems to have this) or through rear hatch. In the Warner "Street Turbocharging" book there's an MR2 (type 1) project that might give you some ideas. One day I might build a Fiyota..................... ![]()
__________________ Wanted: Forged low comp 1100 pistons. | |||
| | #33 | ||||||
| Principality Retained :) | Re: bike engined Seicento Main reason Im thinking is cramming heat management pipework, g/c cables in the same place under the car - I dunno whether there's enough space available. MOving the G/C linkage and cables inside the car would solve that though if you can turn the cables through the necessary radius without impinging on their operation
| | #34 | ||
| Re: bike engined Seicento i need a way of getting the car to work to weld it all in because i dont really want to mess aout on my drive. and you allways never have the right tools. i had a small box tralier so i started cutting it up to amke a car tralier. it the right wheel base so it prob will not get used after this lol. heres a pic before and after painting. adam ![]() still got a bit to do and ive gotta buy some straps to tie the car down. ![]()
| | #35 | |||
| | #36 | ||
| Re: bike engined Seicento ive drilled the gear lever on the engine. and iam making a plate so i can fix the gear shift cables to it with a rod end screwed to the end of the cable fixed to the lever. so it should sort out the gear change but still use everything thats allready there.for the clutch on the bike engine ive got a rear brake cylinder of a bike. and iam fixing the clutch cable from the car to a plate with a lever to push the rod on the cylinder. iam just trying to use whats already there to make things easy. heres a pic of the shocks ive got iam going to mod them to fit so i can play adam ![]()
| | #37 | ||
| ' | Re: bike engined Seicento Nice ![]() What the shocks off? Are you ditching the trailing arm suspension on the rear while you are there? most important......stick as many pics up as you can ![]() To add them to the thread, click the paperclip when posting Cheers, Kristian
__________________ Black Seicento Sporting mk2 1242cc 16V conversion finished and removed! ![]() Megasquirt installed, a constant evolution 1368cc and 6 speed running great now ![]() My Members Motors thread ![]() | ||
| | #38 | ||
| Re: bike engined Seicento these guys will make one for you http://www.zcars.org.uk/ get them to put an engine in the front and back should get 1000bhp woosh.
| | #39 | ||
| Re: bike engined Seicento i ordered the wrong size spocket for the diff so ive had to reorder. the cars being trailered to my factory this weekend so the fun will begin. the engine that i pulled out was a 55k i think. ill have to have a good look its got full service and run mint before it was pulled out. anyone want it collection from telford. adam
| | #40 | ||
| Re: bike engined Seicento heres a pic of me getting it to the factory on my new tralier ![]() ![]() the ramps worked ok ![]() ![]() just made it a bit small i got the wheel base off the net but i dont no if i red it right lol![]()
| | #41 | ||
| Re: bike engined Seicento have you checked out 16vminiclub.com
| | #42 | ||
| custodian of imola blue | Re: bike engined Seicento Shame you painted the trailer.............. ![]() But looking good. What end is the engine going in (you may have said, but I can't remember).
| | #43 | |||||
adam
| | #44 | ||||||
| Principality Retained :) | Re: bike engined Seicento Out of interest - what size and W/T of steel box section did you use?
| | #45 | ||
| Alfa engined Beach Buggy | blu73 | Auction Watch | 19 | 22-06-2006 11:36 |
| Lancia thema 8.32 (FERRARI ENGINED)... | christopher watson | Auction Watch | 6 | 20-03-2006 13:52 |
| Bike Rack for Seicento | cagerrey | Cinquecento / Seicento | 10 | 27-07-2005 17:23 |
| Twin engined cinq | scrw | Lets Talk FIAT | 6 | 30-07-2003 03:32 |
