Technical exhaust emissions
andy majorca
just took my 2001 seicento for mot failed on emissions need a cheap solution, a friend mentioned redex and taking air filter out will this work:confused:
when was it last serviced?
service it (oil, filter, plugs, air filter), put some redex in then take it for a good thrashing.
before the retest, have the engine / exhaust nice and hot.
had it serviced about 3000mls ago, plugs oil,air filters. is redex the same as wynns and how much should i put in
i will try that but f///k knows what you call it in spanish i live in majorca
It's fitted in the exhaust manifold downpipe/catalytic converter.
If yours is an 1100 MPI, Then you have two.
Would be handy to know what the mot test results are from the test sheet before making conclusions.
ok results hope it means something to you .at idle 0.40 and while revving 0.60,over here the maximum is 0.30 at idle and 0.30 while revving this the best way i can describe
may sound like its longer than a day without food, but as from tomorrow i have days without car,i tried bribery at test centre,wasnt having it, will just have to leave it in the hands of diego el mecanico
