Technical when should i strip?
Barnsley
My sei sporting MPI's due a timing belt, so while thats off i'm going to change the water pump too. the question is, the spark plug on cylinder 1's normally covered in oil, while the garage is doing the belt/water pump is it worth stripping the engine and doing the head guasket and sorting out the oil problem, i think its either a valve seal or a piston ring, or should i just wait for it to die?
ask for a cylinder leakage test at a garage, we does this regular, its basically a gauge on the air line which is sensative to slight leaking from the cylinder and will show up a blown head gasket by reading high on the gauge ;)
But done well, you can listen for (or see!) where the air is escaping from, thusly, you can pinpoint leaking valves, worn rings/bores, even tell not only which cylinder but how a head gasket is compromised.
Re the oil on the plug, are you sure it is oil? Might be worthwhile swapping the injectors around (if MPI). Be careful getting them out: do not lever on the plastic electrical connector bit or it'll snap off!
oil on plug number is just spilt oil from filling the engine oil up, it sits on the threads and then when you remove the plug it drips onto it. don't worry about it.
