| Do mod'd Cinqs start and idle ok? You can tell i haven't got much work on this week! Given the number of posts from folk having cold starting and idle problems - do modified sporting Cinqs/Seis not have worse problems? When you take the factory airbox set-up out you also lose some of its cold start system, so surely cold start and tickover becomes more of a problem than in the standard car? After my troubles with the roadpea, i'm keen to have some trouble free motoring with the new Sporting (what am i saying? 'trouble free'? - its a Fiat Cinq duh!!) Maybe i'd be better getting an exhaust rather than an induction kit to get me that extra few HP? cheers D
| mad bad and very very old | Re: Do mod'd Cinqs start and idle ok? When you change anything like that the ECU has to re learn, this can take up to 300 miles. The bottom line is that Fiat spent millions of Lira setting the engine up to work in a variety of conditions, and you've spent a £100 on a modification. There are bound to be issues, and if you can't live with them, leave it alone. Cheers D
__________________ If it has pistons or tits, its going to be expensive. Last edited by rallycinq; 04-04-2008 at 09:58. | ||
| | #3 | |||||
| Re: Do mod'd Cinqs start and idle ok? The previous owner of my car stuck in an induction kit that runs well, and the car idles sweet and smooth. There are no issues with cold start either, but then my engine is different (MPI) so not sure it it's the same in others.
| | #5 | ||
| custodian of imola blue | Re: Do mod'd Cinqs start and idle ok? Really depends how much you modify them! All mine start and run OK....... at least, when the engines are in one peice!
__________________ Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes! | ||
| | #6 | ||
| Re: Do mod'd Cinqs start and idle ok? With a big throttle and airbox mine takes a mile or so until you can open it wide up without it complaining.
| | #7 | ||
| Cinq Sp | Re: Do mod'd Cinqs start and idle ok? Cars can also suffer from this ..Which is why car manufacturers fit the bit that most induction modders remove. (Carb icing is most likely to occur in humid conditions at above 25 dec C BTW)
| | #8 | |||||
| Principality Retained :) | Re: Do mod'd Cinqs start and idle ok?
My Cinq 1242 (small TB / P75 cam ) doesnt idle too quietly, its always been rather lumpy too
| | #9 | ||
| custodian of imola blue | Re: Do mod'd Cinqs start and idle ok? Might be an ideas to do a compression test.
| | #10 | ||
Blog Entries: 15 Thanks: 0 Trader Rating: (0) | Re: Do mod'd Cinqs start and idle ok? i agree with fingers , mine i have had the usual , cam change, chipped, exhaust back box, 38mm T.B and a modified induction system and i have no trouble at all, it always starts first time and i have a smooth idle .
| | #11 | |||||
Vehicle modders can usually live with the chancee that occasionally their engines may suffer from carb icing when the conditions are right but manufacturers have to cater for it.
| | #12 | ||
| mad bad and very very old | Re: Do mod'd Cinqs start and idle ok? So, in fact, what we are actually saying here, is, that despite rumours to the contrary, the K and N filter is the besy for a Cento. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #13 | |||||
I see there's a guy selling a chipped ECU in the classifieds - easy enough to remove the chip and put it in my ECU? (i.e is it a socketed or soldered chip?) cheers D
| | #14 | ||
| custodian of imola blue | Re: Do mod'd Cinqs start and idle ok? You won't know whether it's socketed or soldered until you've popped the ECU. Always best to contact McCritch before buying a chip (assuming it's one of his chips!). If the car is healthy, a decent exhaust, McCritch chip, punto 75 cam, 4 into 2 into 1 mani and tricker TB and GSR should produce 65 to 70 bhp (depending on the rolling road). The result should be a driveable car which starts easily and does better than 40 mpg. It's only when you start sticking really lumpy cams in that problems with idle are likely. Which is why, if you're having starting and idle issues I suggest a compression test.
| | #15 | ||
| Re: Do mod'd Cinqs start and idle ok? Cool - that sounds like a plan then (medium/long term that is!) My tickover problem was in my 900 Cinq - and its sorted now thanks to everyones advice on here - cheers! Started three mornings on the trot now without a touch on the throttle. Now thats fixed i can flog it with a clean conscience and concentrate on getting my new sporting on the road (clutch!) happy days. Only problem is the warning lights still on - apparently you have to get Fiat to reset that or it will stay on forever despite the problem being fixed? Unless anyone on here knows how to reset it?.... PS how does this 'thanks' system work on here and it is important to do that? I should be dishing out thanks all over...
| Tags |
| cinq, idle, induction, modified |
| Poor idle at warm start-up | Fine Fiat | Spider | 1 | 06-08-2007 13:54 |
| Mod'd punto van | Poondash | Auction Watch | 0 | 07-11-2006 12:11 |
| | jamie86 | Cinquecento / Seicento | 32 | 22-11-2004 01:42 |
| Tipo doesn't start after idle | feil | Tipo | 4 | 28-04-2004 18:35 |
