The FIAT Forum
Old 01-04-2008   #1
Trader Rating: (0)
Cinq binding brakes
I have a Cinq fitted with grooved disc's and when braking for longer periods (ie down big hill's) the front brakes get very noisy. I think the noise is the pads staying in contact with the disc but don't know why this is happening.
The pads are in good condition and the calipers seem to move freely when cold.
I'm guessing the calipers are starting to seize, is this a common problem and if so can anyone point me in the direction of a solution.
steveninja is offline
Old 01-04-2008   #2
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: Cinq binding brakes
grooved discs do create noise.do you any other signs of binding/overheating?
custard is offline
Old 01-04-2008   #3
Trader Rating: (0)
Sorry should have stated in my original post that the noise becomes excessive, not just the normal sound you'd expect from grooved discs.
I can't see any signs of overheating on the disc surface (blue colouration) but the brakes become really sensitive and rub until you have driven without using them for a while, when this occurs.
My best guess at the moment is that the calipers stick when up to normal operating temperaure so are in need of a service.
I've changed the brake fluid as well but it's DOT4 so should be allright temperature wise.
Old 01-04-2008   #4
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Who made the brakes? I'm thinking of the possibility of disk and pad being incompatable.
If there's corrossion on the disks you might get noise issues.
If one side is staying on (check by touching disk after a run) it could be a knackered hose.
Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes!
fingers99 is offline
Old 01-04-2008   #5
Trader Rating: (0)
They're EBC disc fitted with EBC greenstuff pads, I've not had any trouble with this combo on a number of other cars.
There's no sign of corrosion, discs look normal with no sign of surface heating.
Both disc's seem to be affected, have checked run out and they're not warped.
Can anyone point me in the direction of a caliper service kit???
Think I'll over hall the calipers if possible as I've renewed all other moving components in the braking system.
Old 01-04-2008   #6
fingers99's Avatar
Trader Rating: (1)
PM Fluffy the Impaler on Club Cento for a kit.
BTW, I'd me very surprised if you see bluing on them, which is why a finger is the best test (or an IR thermometer).
How are the wheel bearings?
Old 01-04-2008   #7
Trader Rating: (0)
Wheel bearings are fine. Have just had the disc's off and the caliper's are not moving as freely as they were last time I checked so may as well sort them out while I'm hunting the problem.
Can you PM me an email address for Fluffy The Impaler?? as I can find his details on Club Cento.
Any other suggestions still appreciated, it wouldn't be the first time I've overlooked something simple.
Old 01-04-2008   #8
fingers99's Avatar
Trader Rating: (1)
eMail is: enquiries(at)eurocarecare.co.uk or ring 01332 345869 and ask for Mick.
Old 01-04-2008   #9
Brooky's Avatar
Trader Rating: (1)
ooooo,ive done the finger thermometer test
Hot hot very hot, i learnt me lesson
16v cinq with ITB's
Brooky is offline
Old 02-04-2008   #10
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
OK, you've learned the hard way. A safer way for anyone who doen't like blistered fingers is to spit on it.
D
rallycinq is offline
(T) Binding brakes - Flexible hose ?? Grayedout Cinquecento / Seicento 14 16-05-2007 23:26
(G) brakes binding flatpro Punto 3 12-05-2007 10:57
(T) cars been standing...binding brakes HELP!!! brummy cinq man Cinquecento / Seicento 4 08-03-2006 13:08
(T) rear brakes binding teulk Punto 11 30-10-2005 12:45
brake binding? Bushboy Leisure Lounge 2 18-08-2005 14:40
