Wurley
How easy/difficult & how much ???
Any recommendatiosn on where to get the parts please . . .
they are only £15-£20 at a motor factors, if its fell to bits just go get a new one
the nut needs to be done up very tight, a bit of scafold poll on a beaker bar wih some one standing on the end tight
is just the bit of middle bearing coming out the back? if that all then just grease it up and hope for the best
When I put it back on do I use an amazingly tiny bit of lube on the shaft it slides onto - or am I getting something wrong?
It shouldn't just fall apart.
To me, this suggests that someone has tried to fit a replacement bearing and failed. Should be a press fit!
Bearings may look fine (they usually do). How do they feel?
Surely it should be done up to the correct torque as stated in the manual
no one got a torque wrench that goes up that high though
As the image shows 48-331.9lbft or 65 to 450Nm, it's 3/4" drive and 1100mm long.What's the range on that one? (I desperately need a 4th torque wrench! )
