| Banned | removing door handles? Right, I'm fed up with having the ugliest door handles ever to grace any car ever produced and so I want to do something about it. Options are : Removing completly and smoothing the door - Removing and get sei/punto handles fitted - Remove, spray black, refit. Now, the only option I can afford is the 3rd. What I need to know is how to remove the handles so that they can be colour coded! any ideas? I Have A Cinq Sporting... ...Click Here To have a butchers
| Nothing's Impossible! | Haynes manual details how to do it, but off the top of my head... dunno[?] lost my haynes[xx(] ![]() The Man that Can
| | #3 | ||
| Banned |
| | #4 | ||
| Join Date: Feb 2004 Location: Loughborough UNI / Banstead, Surrey, United Kingdom.
Thanks: 0 Trader Rating: (0) | If you want a set of pre-dehandled/delocked doors then I may be selling a pair (with a smothed boot if you're intrested)?? Only problem for you would be that they are yellow... All you need once you have removed the handles etc. is a door popper kit which can be fairly easily obtained and installed - then - woohoo... press a button and your door opens for you - how kool is that! (I will defo be doing to the new car as soon as funds allow as I agree that the door handles look sh*te!) Matt It's definatly not a custard now - 'cos I got a red one!!! ------------------------ mattdale@clubcento.co.uk ------------------------ Van Aaken High Boost Turbo engine for sale - "0-60 in the low 7's and enough top end to get you very seriously banned!!"
| | #5 | ||
| Banned | hmmm.. depends on the price cause ill have to respray em i was kinda againced the door popper thing (what if ur bat dies?) but im slowly coming round to it I Have A Cinq Sporting... ...Click Here To have a butchers
| | #6 | ||
Thanks: 0 Trader Rating: (0) | I know what you mean bout the battery dying! It happened to me :p Simple solution is to put a key switch "thing" somewhere (I thought about inside the petrol flap) and wiring it up so it opened the doors (I'm not electrician but it couldn't be that hard to do?) ...or not leave you sub on all day whilst working on the car!!! doh! I personally think that it the coolest thing ever having a button you press and your doors open!! [8D][8D]:D:D Um - price - hadn't thought about that - care to make an offer?? Cheers, Matt It's definatly not a custard now - 'cos I got a red one!!! ------------------------ mattdale@clubcento.co.uk ------------------------ Van Aaken High Boost Turbo engine for sale - "0-60 in the low 7's and enough top end to get you very seriously banned!!"
| | #7 | ||
| Yellow Cinq Abarth :D Join Date: May 2004 Location: In A Place...... Far Away From You
Thanks: 0 Trader Rating: (0) | With the door popper kit, does it act like normal door handles, meaning if the door's are locked wit remote central locking the button wont open the doors untill you unlock the car?? Might sound a dumb question but just wanted to make sure, didnt want no scum to just get in by finding the button
| | #8 | ||
| haynes guide to removing door handles. working at the rear edge of the door unscrew the exterior handle however make sure you retain the screw to avoid problems later on. Slide the handles towards the front of the door, then pull the handle out of the door, then carefully prise the lock operating rod from the lever on the lock cylinder. With draw the handle assembly. REFITTING Reffiting is a reversal of removing. but make sure that the lock operating rod is securely reconnected to the lever on the lock cylinder. Make sure that the windows does not mess with it then screw everything together. following the reversal of removing it. hope that helps in some way
| | 4dog | Uno | 6 | 02-04-2004 17:33 |
| 1978 spider - removing tranny | wes | Spider | 5 | 23-03-2004 03:44 |
| | BigSte | Bravo / Brava | 2 | 16-03-2004 01:54 |
| | mycopse | Marea | 4 | 21-10-2003 13:18 |
| removing paint from paint :) | ben | Bodyshop | 3 | 03-05-2003 15:53 |
