The FIAT Forum
Old 19-03-2008   #1
MAY44T
Trader Rating: (0)
s786m has donated! United Kingdom
Fuse keeps blowing
Hi
My fuse keeps blowing everytime i put anything in my cig lighter... I have just put a new headunit in but it blows even when it is off.
Obviously the head works on a different fuse circuit to the heaters and 12v... any ideas?
s786m is offline
Old 19-03-2008   #2
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: Fuse keeps blowing
i would look to the rear where you have ben working on the HU
most likely you disloged a wire and its shorting out. did you have to change any wiring?
nothing extra like neons wired in?
custard is offline
Old 19-03-2008   #3
MAY44T
Trader Rating: (0)
Did not change anything... just run RF and remote leads from HU to rear...
s786m is offline
Old 19-03-2008   #4
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Its possible you've picked up a cable on the cage when you've put the new unit.
D
rallycinq is offline
Old 19-03-2008   #5
MAY44T
Trader Rating: (0)
Was messing about with it earlier.. when the HU is connected but out of the cage its fine... but when it goes back in it blow...
would some insulation tape solve it?
s786m is offline
Old 19-03-2008   #6
rallycinq's Avatar
Trader Rating: (1)
Could do, as long as you find the short.
D
Old 19-03-2008   #7
MAY44T
Trader Rating: (0)
Would the short usually occur when bare metal is touching some sort of wiring?
s786m is offline
Old 20-03-2008   #8
rallycinq's Avatar
Trader Rating: (1)
Absolutely.
D
Old 20-03-2008   #9
Turbo MPI Seicento
gazzaman2k's Avatar
Trader Rating: (0)
gazzaman2k has donated! United Kingdom
i had an aftermarket cig lighter that done this? is it the standard fiat one or not?
Project Seicento
gazzaman2k is offline
Old 20-03-2008   #10
MAY44T
Trader Rating: (0)
Originally Posted by rallycinq View Post
Absolutely.
D
Thanks Rallycinq will try it...
It the standard one...
s786m is offline
Tags
fuse blowing
(G) Bravo Fuse Blowing varcoe88 Bravo / Brava 3 10-03-2008 18:28
(T) Punto 85sx 1.2 1998 - Services Fuse keeps blowing amanda123 Punto 3 29-12-2007 20:07
(T) fuel pump fuse blowing randomly - help!! arc Cinquecento / Seicento 16 25-02-2006 19:50
HELP..Injection System Fuse Blowing Mac Leisure Lounge 1 14-06-2002 05:00
