| brake problems hi, well when im going down the road occasionally (getting more frequant now) the brakes begin to bind on thier own, a extreemly loud squeek begins and such. when i quickly jab the brakes it stops for a while. now i kno its the brakes because when i get out the wheel is hot, and i mean HOT. i ahve burned myself on the alloy haha. now it has done this before then suddenly stopped. its had new pads a month or so back and all looks fine. could it be simply abit of rust obstructing pad movement or is it something else?
| custodian of imola blue | Re: brake problems Clean everything until it's spotless and try again. Find out which wheels it's happening on. Likely causes are a perished (partially collapsed) flexi hose, but if on more than one wheel, it's probably a servo fault.
__________________ Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes! | ||
| | #3 | |||
| 1242 turbo cinq! | Re: brake problems
__________________ | |||
| | #4 | ||
| Re: brake problems hi wil check pipes tomorro, am in work in the car so cant take it all apart but i THINK its doing it on both wheels. but ive only ever checked drivers side for heat. as its there when i get out! .also like i said its happened in the past, but when i changed the pads the piston moved freeley then, so its probably not that. as it had done it before the change too. just not for a while
| | #5 | ||
| 1242 turbo cinq! | Re: brake problems well next time it does it feel for the car pulling to one side that would be an indication to it being one side more than the other, and well just a case of (as said) cleaning pad slides and checking pipes etc, check the pistons again when looking.
| | #6 | ||
| Re: brake problems ok will do. thankss for your help and will let u kno what i find haha.
| | #7 | ||
| 1242 turbo cinq! | Re: brake problems ok no probs let me now what it turns out to be
| | #8 | ||
| Re: brake problems not had chance to go underneath due to the rain here. but the front right is defo wearing more than the front left.
| | mitchellinman | Stilo | 9 | 12-12-2007 20:10 |
| | Cinqster355 | Cinquecento / Seicento | 15 | 30-12-2006 23:57 |
| | garyaird11 | Cinquecento / Seicento | 1 | 03-09-2006 00:30 |
| | punto_ollie | Punto | 1 | 09-08-2006 01:01 |
