The FIAT Forum
Old 08-07-2004   #1
Trader Rating: (0)
Engine running probs 899cc sx
Hi everyone, this morning and again this afternoon my cinque tickover has increased to (guessing 1500 2000 rpm) and then slowly dropped down to normal and just as i got home it stated reving up again to perhaps 3000 rpm, i turned of the ignition and then back on again and it wouldnt start after about a minute it started but was running on what sounded like 2 cylinders with a very strong smell of fumes/petrol i reved it a few times and stopped and started it and it gradually cleared in about a minute and was then running back to normal again iwas convinced that i had a petrol leak but it appears dry under the bonnet and no pipes seemed to have dropped of the injection unit etc. and the visable ecu plugs seem secure and dry.
If anybody has any idea what this might be or has previously sorted this out i would appreciate the help.
Is this just a case of severe rain over night seeped in to a elec. plug somewhere shorting out a critical value?
any help is greatly appreciated thanx heli_red:D
helicopter_red is offline
Old 08-07-2004   #2
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Start by having a look at the map sensor. Remove the pipe and blow it out. If that doesn't help, it could be the lambda.
D
Grumpy old git going fast downhill rather than downhill fast!!
rallycinq is offline
Old 09-07-2004   #3
Trader Rating: (0)
hi thaks for the reply, sorry to show my ignorance but which one is the map sensor
again thanx for any help cheers
Old 09-07-2004   #4
Trader Rating: (0)
Look at the ECU, to the left is a black/grey box upside down, look under this and there is a pipe coming from it. Carefully take the pipe off and the same to the front of the engine. Give it a very hard blow as oil may/will come out of it. And then refit.
MIke - Sei-Mad
Shopping List:
-40mm Lowing Springs
Cadamuro Rear Spoiler
Window Tints
Scrapped 1.2 Punto
Sei-Mad is offline
Old 10-07-2004   #5
Trader Rating: (0)
Hi gang checked the pipe it was dry and not blocked allthough hard to blow through but i persume that is because it is a small pipe that is quite long!! when the engine was running disconecting it changed the revs slightly and there was a strong vacumn on the pipe, i persume this is normal?
struggling to start sometimes then runs really badly until you have revved it a bit and smells really strong with petrol sometimes when driving along and you put your foot down the engine has absolutely no power to give and sort of feels like it is makeing it slowdown then a few seconds later it is ok also i have done about 80 miles on a quarter of a tank of petrol although i only use the car for short journeys which are always in traffic and i am very heavy footed not sure if this is usual fuel consumption or not.
Thanxs for reading any help or advice is appreciated Heli_red
Old 12-07-2004   #6
Trader Rating: (0)
Well from saturday onwards it has been back to its normal self of the warning light coming on now and again but starting and running ok, so i will put the experience down to rain in a conector somewhere, but would anybody have any ideas which one would cause these symptoms as i cant find anything obvious?
thanks for any help
Old 14-07-2004   #7
Trader Rating: (0)
The strong smell of petrol could be fuel leaking from the filler cap, see this thread:
http://www.fiatforum.com/forum/topic.asp?TOPIC_ID=12175
My Cinqy gets stinky if I give her more than half a tank!
Gman is offline
Old 15-07-2004   #8
fixitagaintomorrow's Avatar
Trader Rating: (0)
fixitagaintomorrow has donated! United Kingdom
Could be a problem with the water temp sensor, if the ecu thinks the engine is cold it'll up the idle speed and bang more fuel in.
Pete.
Links: 1242cc cinq, turbo cinq, Cinqs&Seis forum, Clubcento
fixitagaintomorrow is offline
(T) MK2 1.2 8V Engine probs.... username Punto 3 10-07-2004 03:30
(T) Flucuating Revs and Engine running on when off MK8100 Punto 4 24-04-2004 05:19
(T) hgt engine running temprature anthemmaster Bravo / Brava 7 27-01-2004 05:46
(T) Marea 155 Engine managment (probs) ginjaninja Marea 1 20-10-2003 16:57
(T) Uhoh! - Cinq engine probs smurfhead Cinquecento / Seicento 3 05-06-2003 23:37
