| The Little Blue Tractor | Morning. I am intreeged as to what head skimming is. Could someone explain to me:- What the head is? (is it head gasket?) What will head skimming do? And how would I go about it? Thankyou. I'll be bk on this afternoon to see the verdict. ![]() ![]() Aj x
__________________ AJ x ------------------Fiat Cinquecento 0.9 = 2007-2008 Seat Arosa 1.4 = 2008 | ||
| umop apisdn | Re: Head Skimming The cylinder head is the top part of the engine. It sits on top of the engine block. Where the two join there is a gakset. This is the head gasket. The head and block both need flat, straight, clean surfaces. If an engine has over heated the head can twist or warp (very very slightly, we are talking fractions of a millimetre). Or corrosion can wear away some of the face of the cylinder head. If either of these happen then you need to remove the head, clean it up and then cut a very small amount off the face of the clyinder head. This is called skimming, as the tool only just skims the surface being cut. But you can use skimming to aid performance. If you skim a certain (calculated) amount off the head, when you re-fit the head the space that the air / petrol mix is compressed into (the combustion chamber) is smaller, and this means the compression ratio is higher, and as a general rule a higher CR gives slightly more power. But you must work it out, and you must not go too high. So, there you are, two reasons for skimming. Cost for a light skim is about £30 ish.
__________________ Your sister is hot, but your mum does that thing with her tongue Last edited by balidey; 09-03-2008 at 10:53. | ||
| The following user says "Thank You!" to balidey for this useful post: | ||
bandido41 (11-03-2008) | ||
| | #3 | |||
| The Little Blue Tractor | Re: Head Skimming
Ohh thankyou. was a very detailed explanation. and now know what it is .Thankyou! Aj x
__________________ AJ x ------------------Fiat Cinquecento 0.9 = 2007-2008 Seat Arosa 1.4 = 2008 | |||
| | #4 | |||||
| Re: Head Skimming
| | #5 | ||
| __________ | Re: Head Skimming
__________________ Binki | ||
| | #6 | ||
| | #8 | ||
| | #9 | ||
| __________ | Re: Head Skimming ive got loads of them http://www.fiatforum.com/gallery/sho...ry.php?cat=855
| | #10 | |||
| Re: Head Skimming
__________________ 16v cinq with ITB's ![]() | ||||
| | #11 | ||
| Re: Head Skimming my last 899cc head gasket went . but then i crash so no need to fix .Is actually not that hard at all, to get the head off .Ming
| | #12 | ||
| custodian of imola blue | Re: Head Skimming
__________________ Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes! | ||
| | #13 | |||
__________________ Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes! | |||
| | #14 | |||
Secondly, think about the axis the cam is in relative to the head, if a head is REALLY badly warped, the main twisting action will be diagonal corner to corner, lets say 1mm. This distortion will be along the line of the cam, so the head is rotated about this axis, so therefore the cam will still be relativly straight. Very hard to explain. Try again. Get a show box (the head) stick a knitting needle through it (the cam) twist the box. Has the needle bent? No. And this is how heads tend to distort, one corner lifts (well from my experience) you don't get side to side bending as the hardened steel cam tends to re-inforce the softer alloy head. Make sense?
__________________ Your sister is hot, but your mum does that thing with her tongue | |||
| | #15 | ||
| Get a wriggle on! | Re: Head Skimming if it aint broke, dont try to fix it!!
__________________ | ||
| | philmoore | Punto | 6 | 11-03-2008 19:36 |
| FAO a mr potato head | SkinzCinqSporting | Leisure Lounge | 29 | 16-12-2006 20:49 |
| | dbriglee | Punto | 2 | 19-01-2006 23:19 |
| rally strata | fiatman | Other Fiats | 8 | 24-01-2005 19:34 |
