on the turbo car a peugoet 34mm throttle body has been fitted and i want to no why this item is fitted and not the 40mm body i want (and hope to fit), but dont no if anything has been changed on the manifold etc to fit the french item, has anyone heard of a turbo with a peugeot body on it? also the rs2000 or coupe turbo fuel pump,,,when fitted what will have to be the next step and how do i go about the pressure regulator?
once these are done the head is coming of and a thicker (or twin) head gasket is going on to lower the comp and the head is getting ported poilshed and bigger valves fitted and manifolds ported to match,and im having thorts on having the cam reprofiled to? then along with the intercooler im going to run the 0.5bar the car runs now for safty. either water injection or boost control is something im going to do too!. any advise or opinions on that set up?
