| Stiff gear changes I am a new sei sporting owner and drove the car today noticed clunking from rear. Suspension seems fine and has just passed an MOT yesterday so could be something else. Also the gear changes are a bit on the stiff side. Is this normal or does it point to a dodgy clutch or gear box? Help would be appreciated. Thanks
| custodian of imola blue | Re: Stiff gear changes The clunking probably is the rear suspension arm bushes (or maybe an improperly fitted exhaust): chances are the MOT folk missed it. For the stiff gearchange, try adjusting the clutch cable. A search should reveal all.
__________________ Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes! | ||
| | #3 | ||
| Re: Stiff gear changes helo my siecento sporting was doin the same thing they have told me i need 2 new front shockers and as for the gears i need a new rear gear box mount because it had came away from the rubbers you should take it to your local garage and get it checked over for free
| | #4 | ||
| MAY44T | Re: Stiff gear changes I had the same with the suspension, i just got it lubricated... sorted it out... as fingers99 said, for gear changes, clutch adjusment view thread http://www.fiatforum.com/cinq-sei-te...-gear-box.html
| | #5 | ||
| Re: Stiff gear changes I got a cinq sporting a few weeks ago.. was hard to shift, grinding into reverse, noisy, and got only 30 mpg. After total service tune up, flushed out oil, new sparks, etc... with clutch cable replaced, it was like a totally different car, now gets 46mpg and gear shifting is great... 87,000 miles and I'm the tenth owner! Gianni
__________________ 96 Cinquecento Sporting | |||
| | #6 | ||
| Re: Stiff gear changes Try filling the gearbox up with gearbox oil. if my Cinquecento's geabox gets low it gets stiffer and crunches a bit jb88
| | #7 | ||
| | #8 | ||
| Re: Stiff gear changes it could be something as simple as you using too thick gearbox oil.. try whack something a bit thinner in.. do you find the gear changes are alot stiffer when the engine is cold ?
| | zak20VT+ | Marea | 10 | 02-12-2008 21:37 |
| | GhostWKD | Cinquecento / Seicento | 17 | 22-09-2004 07:06 |
| | polecat | Marea | 0 | 15-02-2004 23:09 |
| | Pete600 | Cinquecento / Seicento | 10 | 08-05-2003 05:33 |
