| Boot opening pull?? Currently considering buying a sei. I went to see what yesterday which was pretty good except the boot release pull next to the driver seat did operate. The actual handle moved but didn't pop the bootlid. Firstly, anyone know whats likely to be up with it?? And secondly is it much of a job to fix?? Not too bothered if I can fix it if I buy the car, also gives me something to use against the seller to knock a few £££ off :p Cheers Matt
| taffy git | dont laugh, but did u check to see if boot was closed to begin with[?] it depends where its actually gone, the handle end or in the boot mechanism, its not that hard too fix, ive never had to do it myself but i would imagine, you would just need paitence to fix it ![]() Seicento Sporting, Modified Front Bumper, Saxo Custom Spoiler, Abarth Side Skirts, Bad Boy Bonnet, Afterburner Rear Lenses, 4" Powerflow Exhaust System, Abarth 14" Alloys. IN THE PIPELINE: -40mm Drop or Coilovers, New Front Bumper, Rear Splitter, New Mirrors (Not the cup ones[xx(], something different) Check out my site http://badboygaz.mysite.freeserve.com FIATForum stickers available PM me for details or see: http://www.fiatforum.com/forum/topic.asp?TOPIC_ID=10000
| | #3 | ||
| something daft like the cable fell off wouldnt surprise me in the slighest :D -=[uno 1.0ie RAAAWW!]=- -=[fiat tech for what it's worth.]=-
| | #4 | ||
| I had to do this to mine. The boot mechanism end wasn't working. Open the boot with the key then pull handle up from the inside and wedge something underneath it. Then go and have a look at the lock, see if the release pin (car body side) has moved. If it has then the problem is at the boot end, if not the problem is at the handle end. I don't know how to fix the handle end but the boot end will either be a snapped release pin (scrappy job) or the pin may just need to be bent back into place slightly as it has moved over time. Hope this helps. Sei Devil
| | #5 | |||||
Matt
| | gisburne | Marea | 26 | 10-07-2006 23:24 |
| Boot Door | MWG_T_H_O_M_A_S | Panda (Classic) | 3 | 11-07-2004 03:55 |
| Driveshaft outer boot.. | John H | Panda (Classic) | 3 | 30-11-2003 19:23 |
| | Sando | Cinquecento / Seicento | 8 | 16-09-2003 22:26 |
