Blog Entries: 15 Thanks: 0 Trader Rating: (0) | Wheel Spacers / Wheel Bolts hello I can't remember what thread i read but i am sure there were some longer wheel bolts i can take off an alfa or fiat i can use when putting on 10mm spacers on the front of my cinq. any ideas? thanks Ricky
| custodian of imola blue | Re: Wheel Spacers / Wheel Bolts 10mm may be a bit much. Pop into your local Alfa dealer with your old bolts, see what they have. Failing that, places like Tweeks and even eBay will have something to suit. The thread is 12x1.25.
__________________ Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes! | ||
| | #3 | ||
| The Thrill of Driving.... | Re: Wheel Spacers / Wheel Bolts Fiat Seicento Abarths fitted with 14" 5.5J ET36 wheels have 10mm spacers at front as standard with stud conversion. The spacers are very well made and about £32 from Fiat IIRC. The studs are very expensive from Fiat, so better off using normal longer studs which are widely available from retailers like Rally Design. Though it has to be asked, why do you want them?
__________________ ![]() 1992 Lancia integrale EVO1; 1995 Toyota Celica GT4 ST205; 2001 Seicento Abarth 1.4 16V 6speed (OK that one's Emma's) | ||
| | #4 | ||
Blog Entries: 15 Thanks: 0 Trader Rating: (0) | Re: Wheel Spacers / Wheel Bolts thanks for that would you know what length to buy? thanks ricky
| | #5 | ||
| custodian of imola blue | Re: Wheel Spacers / Wheel Bolts As rule of thumb, full length of existing bolt, + 10mm (for your spacer). They're generally available in 10mm increments, so go longer rather than shorter. Don't forget you need nuts to suit (I prefer the open end ones) and you'll need locktite, a decent solvent (to clean the threads in the hub -- petrol or spirit wipe) and a little coppaslip for the exposed threads (means the nuts come off more easily so you don't end up winding the stud out rather than the nut!). But, like the man says, what are you doing?
__________________ Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes! Last edited by fingers99; 29-02-2008 at 15:03. | ||
| | #6 | ||
| Re: Wheel Spacers / Wheel Bolts The original length of a sporting bolts is 23mm (taking into acount they have 3mm spacers) So you will need 30mm wheel bolts for your cinq.? I think these should do, http://cgi.ebay.co.uk/Fiat-alloy-whe...QQcmdZViewItem And you can get the OEM fiat spacers from the sei abarth, I'll see if i can get the part number for you, when i get home. (Don't get universal spacers, they will making your steering shake, not good at all) They cost about 40 quid for a set. Ming
| | #7 | ||
| custodian of imola blue | Re: Wheel Spacers / Wheel Bolts I'd suggest not going the bolt route. The Abarth way is fine. The stud way is fine. To my mind, studs make it easier late at night when you're kneeling in a puddle. Don't use universal spacers, but you can get plain spacers (at 10mm you don't need hubcentrics) with Fiat/Alfa PCD and the right centrebore.
| | #8 | ||
| Re: Wheel Spacers / Wheel Bolts The stud way is extremely expensive compare to getting the bolts when i checked. If you can the wheel locator bolt (i think that's what they called) from fiat as well, then the spacers will be held in place, and putting the wheel on will just be the same as before but with longer bolts. But yes, if u got the cash, i would recommend going for the stud conversions .Ming
| | #9 | ||
| Re: Wheel Spacers / Wheel Bolts Wheel bolts ~£1.20 each Studs~£0.60 Nuts~£0.80 Rough prices but only an extra £3.20 for stud conversion Im doing it soon as ill be using steelies and alloys and cba carrying another set of shorter bolts around for the steelies
__________________ 16v cinq with ITB's ![]() | |||
| | #10 | ||
| Re: Wheel Spacers / Wheel Bolts link to get them ???Last i checked was with fluffy.
| | #11 | |||
__________________ Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes! | |||
| | #12 | ||
| Re: Wheel Spacers / Wheel Bolts again i got some from fluffy, and they are original fiat ones . I'll get the part number for them when i get home.It was Kritrip that gave me the part number. Ming
| | #13 | |||
| Re: Wheel Spacers / Wheel Bolts rally design Any rally place will do them. Rally nuts, merlin, my local RSM does them
so i carnt make anyEDIT:Im thinking of the wrong bit here,lol, thought you were on about the thing you can put in to help you put the wheel on
__________________ 16v cinq with ITB's ![]() Last edited by Brooky; 29-02-2008 at 15:53. | ||||
| | #14 | ||
Blog Entries: 15 Thanks: 0 Trader Rating: (0) | Re: Wheel Spacers / Wheel Bolts Sorry J33EVO/Fingers99 i missed the bit of the thread to the reason why i want them, the reason being i heard if you add spacers at the front the handling of the car will be better i.e more responsive? Ricky
| | #15 | ||
| Re: Wheel Spacers / Wheel Bolts What do i need to ask for liek the pitch, and stuff like that (i'll got no idea) Studs -? Nuts -? Thanks Ming
| | BigAl54 | Grande Punto | 2 | 06-05-2007 22:04 |
| | Robin1600 | Cinquecento / Seicento | 7 | 02-05-2007 08:25 |
| Locking Wheel Bolts | seanb | Ulysse | 7 | 19-01-2006 13:30 |
| | AIJ29 | Cinquecento / Seicento | 2 | 29-07-2005 20:16 |
| | ts86 | Uno | 5 | 30-09-2004 20:58 |
