The FIAT Forum
Old 06-07-2004   #1
Trader Rating: (0)
Gearbox oil leak...
My Cinq has been leaking oil from the drive shaft seals (on both sides) for some time now and I finally bit the bullet and took it in to get it repaired this morning. I was just wondering if the gearbox oil is the same oil that lubricates the rest of the engine? In my old car the gearbox oil was seperate but I couldn't find a separate filler for the gearbox oil on my Cinq so I'm wondering if it's all the same oil? Just wanted to know to make sure all of the oil hasn't leaked out. It's a Cinq S 896cc OHV.
Gman is offline
Old 06-07-2004   #2
Trader Rating: (0)
there is no filter on your gearbox, only autos have gearbox oil filters afaik.
gear oil is quite different too engine oil, best not mix them up :D
-=[uno 1.0ie RAAAWW!]=-
-=[fiat tech for what it's worth.]=-
kebab is offline
Old 06-07-2004   #3
The Ugly Duckling's Avatar
Trader Rating: (0)
I had this problem a while ago, but it only happened on one side. The oil's very different to engine oil. You can buy it from Halfrauds etc. The drive shaft gater thing cost me £6, but the oil cost £18 from Halfrauds. It'll probably cost a lot more to get fitted though [V]
The Ugly Duckling is offline
Old 06-07-2004   #4
Principality Retained :)
Trader Rating: (3)
arseofbox has donated! United Kingdom
Yeah it stinks for a start.
I was advised my a Motor Factor to just do up the gaitor tightly with a cable tie (tie wrap), and then it was OK'd wih a mechanic mate of mine. Given the amount of oil in my gearbag atm (lots), they seem to be the only part of the GB that isnt leaking :)
Tom (AofB)
95 Cinq Sporting - Rattly GrpN Catback Exhaust, <font color="black">Buckets</font id="black"> and 3pt Harnesses,Sexy VW styleé dials (that look great, but dont work!! (:D)), 10" Sub and 6x9's, ETech Wing. Lots of Dirt!
1242cc Engine in car, not starting, boot delock soon, K+N still in garage!
arseofbox is offline
Old 06-07-2004   #5
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
There is a gearbag filler, but it don't look like an engine oil filler. Its a hex headed socket bolt, I think in the rear of the box. Its about half way up and indicateds the level. You open the filler and add oil until its coming back out the hole. This assumes the car is level. The oil is then at the correct level.
Gearbags use a hypoy oil which does not break down under crushing, ie going between gears. It is sticky smelly stuff, but does its job. There are a range of synthetics available which are expensive but superb.
D
Grumpy old git going fast downhill rather than downhill fast!!
rallycinq is offline
Old 06-07-2004   #6
Trader Rating: (0)
D
The gearbox oil filler is on the front of the gearbox. If you're standing in front of the car looking at the bonnet then the gearbox oil filler is to the right, just under the airbox (on the 899cc ones). I needed to run the oil down a small tube down to the hole, I don't think you'd be able to get the actually bottle down that far into the engine [V]
Old 06-07-2004   #7
rallycinq's Avatar
Trader Rating: (1)
Its a while since I did an 899. Thats my excuse and I am sticking to it.
D
Old 06-07-2004   #8
Trader Rating: (0)
Cheers for the help guys - I'm picking up my little Cinq tonight. There was some work to do on the handbrake too (not really surprising), so with that plus 2 drive shaft seal replacements I'm expecting a hefty labour bill. :(
Gman is offline
Old 07-07-2004   #9
Trader Rating: (0)
D
You were mostly right, I think it is a hex head socket and you do fill it until it overflows [^]
Old 05-02-2006   #10
Trader Rating: (0)
gearbox is pig
help why is the geartbox on cinq very hard notchy to engage recent clutch n cable tried adusting toped up the oil what else its getting on my t..ts
pikeman is offline
Old 05-02-2006   #11
Trader Rating: (0)
Re: Gearbox oil leak...
FILLER
Sometimes i like to disappear into my own little world, but its ok they know me there.
vandisian is offline
Old 05-02-2006   #12
Trader Rating: (0)
D
12 mm socket on front of my SX box
Old 05-02-2006   #13
Trader Rating: (0)
btw what does afaik mean
Old 05-02-2006   #14
rallycinq's Avatar
Trader Rating: (1)
As
Far
As
I
Know
D
Old 06-02-2006   #15
Trader Rating: (0)
cheers mate guess im not down with the kids
(G) fuel leak tommyd Punto 5 15-11-2005 19:45
(T) gearbox help marky23 Punto 5 02-06-2004 00:31
(T) gearbox update....please help StreetRacer Punto 7 31-05-2004 00:50
1986 March 965cc Panda 4x4 gearbox et al waddow Panda (Classic) 2 10-12-2003 03:21
Panda Gearbox steveyensen Panda (Classic) 62 09-07-2003 16:21
