The FIAT Forum
Old 24-02-2008   #1
Trader Rating: (0)
Saxdaddypops has donated!
Bizarre overheating issues?
Hi guys, I have Sciecento ,which seems to run VERY warm have changed thermostat ans sensor on 'stat ,have also bridged the fan but STILL the temp light fades in and out bright on idle fades at 50 mph + ???? Is there another sensor?? conected to the light , water in expansion tank is warm but NOT boiling up and I have HOT water coming out of bleed valves and ALL hoses VERY HOT ???THOUGHTS fan never kicked in on own? so is it TOO hot??
Saxdaddypops is offline
Old 24-02-2008   #2
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
chaos has donated! United Kingdom
Re: Bizarre overheating issues?
Does the fan actually work?
Chaos - Life wouldn't be the same without it.
Cinq parts clearout!
chaos is offline
Old 24-02-2008   #3
Trader Rating: (0)
yes fan works fim=ne when a paper clip used to bridge the radiator connection
Old 24-02-2008   #4
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
MPI or SPI Sei?
Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes!
fingers99 is offline
Old 24-02-2008   #5
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
I am guessing SPI as the MPi takes its fan signal from the ECU. I wonder whether this is another case of the srong sensor in the head.
D
rallycinq is offline
(G) Overheating problem! stu2525uk Bravo / Brava 18 30-08-2007 09:28
(T) Issues to look out for when buying UTs? axnutty Uno 16 10-05-2007 20:42
(T) Brava Overheating showard Bravo / Brava 9 01-06-2006 09:41
(T) Bravo overheating wierd DanBravo1.6 Bravo / Brava 12 11-01-2006 17:32
(T) Overheating Irish lass Punto 8 27-10-2005 10:28
