| seicento will not start Can any body help me? I have a Seicento sporting which will not start. The back ground is as follows. 1) Over heated as radiator failed. Replaced radiator. 2) Still overheating and air in the coolant header tank so head gasket replaced (inc timing belt). 3) Still overheating which was eventually traced back to cooling fan switch. Whilst ticking over, warming the engine up to test all is OK for the second time (so it had been running for 20 - 30 min) it just cut out and has not started since. I have checked the obvoius, fuel & spark and checked that I have not left anything unconnected but it still will not fire.
| Re: seicento will not start Bit of a long shot put has the inertia switch been activated? It happened to my car, its unlikely but possible.
| | #3 | ||
| Re: seicento will not start How would I know and where would I find it?
| | #4 | ||
| Re: seicento will not start I forgot to add the whilst the enginee does not start it does turn over and tries to fire.
| | #5 | ||
| Re: seicento will not start Is there a strong smell of petrol after repeated attempts at starting ?
| | #6 | ||
| Re: seicento will not start Its there but I would not say strong.
| | #7 | ||
| mad bad and very very old | Re: seicento will not start Are you saying that you have fuel at the injector and a spark? Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #8 | ||
| Re: seicento will not start Yes I believe so.
| | #10 | ||
| Re: seicento will not start SPi MPi? What do you mean?
| | #11 | ||
| RIP L181 VBB | Re: seicento will not start SPI = MK1 sei 98 - oct 00 MPI = MK2 sei oct 00 - end of UK life Whichever year yours is will determine whether it is SPI or MPI
__________________ ![]() 2001 Modded Sei Sporting - GONE!! 1998 Ford Mondeo 1.8LX - P/X'ed 2002 02 Ford Focus 1.6 Zetec w/ Climate Pack! Last edited by AppleSei; 23-02-2008 at 16:57. | ||
| | #12 | ||
| Re: seicento will not start SPi is Single point injection & MPi is Multi point injection.
| | #13 | ||
| Re: seicento will not start OK. SPi then.
| | #14 | ||
| mad bad and very very old | Re: seicento will not start OK, pop the filter off and while someone turns the engine over observe for fuel from the injector. It should be easily visible. Cheers D
| | #15 | ||
| Re: seicento will not start I have now recharged the battery and can confirm that yes I can see fuel at the intake when it is cranking over.
| Tags |
| seicento, start |
| | custard | Cinquecento / Seicento | 72 | 1 Hour Ago 00:54 |
| Help with.... | Dobby | Leisure Lounge | 51 | 02-11-2007 17:56 |
