| Wheel big problem I got some spare cinq wheels for my car as 2 were damaged. They dont fit though. The studs are the same and look identical to cinq wheels but the offset is wrong. Has anyone any idea what they are off and how i can get them too fit. Please help me. Cheers paul.
| Moderation in Moderation | probably off an uno (they look the same), they should fit with spacers i think Abarth Kitted Cinq Sporting, New lil siggy pic coming soon, till then.... not much really lol
| | #3 | ||
| You any idea were i can get spacers from??? Are they particular to cinqs?/?
| | #4 | ||
| Moderation in Moderation | not sure what size spacers you'd need as am not sure what offset the uno is spacers are universal though Abarth Kitted Cinq Sporting, New lil siggy pic coming soon, till then.... not much really lol
| | #5 | ||
| 5mm spacers from Fiat Coupe should be fine. Uno has 35mm offset.
| | #6 | ||
| Tempra, I'd guess - do they have a ridge in the outer edge, just under where the wheel balancing weights should be? Read the figures off the wheel - something like 5.5j13 H4 42 then get back to us fella. Pete. Links: 1242cc cinq, turbo cinq, Cinqs&Seis Yahoo group, Clubcento
| | #7 | ||
| the code on the wheels is, 5.5J x 13h - 42.5 On normal cinq wheels the code is, 5.5J x 13 h2 - 30.5. Will i need longer studs if i put spacers in. Are the spaced wheels best on front or back and will it cause any handling problems? Cheers people.
| | #8 | ||
| Righty ho, I'd suggest you need 12mm spacers along with 12mm longer bolts to bring everything up square again. If you're gonna fit them, I'd suggest you use them either both on the front or both on the rear. What tyres have they got on? You might find it easier to flog them on and get some cinq wheels second hand rather than faff on with spacers and new bolts. Pete. Links: 1242cc cinq, turbo cinq, Cinqs&Seis Yahoo group, Clubcento
| | #9 | ||
| Cheers pete. Dont really want to muck about finding cinq wheels. took me long enough to get hold of these. Selling the car now anyway. Thanks for your help. Nibbo x x x
| Tip timing problem? | Akeldama | Tipo | 4 | 01-08-2004 05:54 |
| Mid-throttle injection problem in Lancia Y10 | FatNote | Panda (Classic) | 26 | 30-07-2004 18:58 |
| Wheel Changing | Stu DemonD | Ulysse | 11 | 13-07-2004 02:35 |
| | PuntoRob | Punto | 5 | 29-04-2004 18:43 |
| Brava lockup problem | Kensho | Lets Talk FIAT | 1 | 11-11-2003 03:05 |
