| Got a Cinq Sporting that after a really cold morning started to overhead. I think the cold temperature that night caused something to break, like the thermostat freezing caused it to get stuck in closed position... If I run it: It easily gets up above 110degrees, with no fan kickin in... If I leave it on idle: It easily gets up above 110degrees, with no fan kickin in... Checklist: * - There is enought water in the expansion tank (no leak). * - The water in the expansion tank gets really hot. * - The incar fan blows really hot air when the engine is on but just cold air when the engine is off (waterpump working I guess?) * - Oil looks good (headgasket not blown?) * - Idle Vs. Driving fast makes no difference, (guess the water is not passing the radiator) Assumption, thermostat stuck in closed position? Or could it be something else? ( I have never heard/seen the fan moving, not sure it ever has worked soo I don't think that's part of the problem )
| custodian of imola blue | Re: Overheating Sporting Is there any anti freeze in it?
__________________ Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes! | ||
| | #3 | ||
| Re: Overheating Sporting yes there's antifreeze in it.. (not sure about the mixture though, but on the other hand it has not been -that- cold soo far this season)
| | #5 | ||
| Re: Overheating Sporting I don't think the radiator gets hot but I've not been able to actually verify it yet, I'll check it after work.. If we assume the radiator is cool, it more or less must be the thermostat that's broken?
| | #6 | ||
| custodian of imola blue | Re: Overheating Sporting Or the radiator has frozen solid..........
| | #7 | ||
| Re: Overheating Sporting I had a problem with this last december,found out that the waterpump was leaking so replaced it and also replaced thermostat and works great ever since no problems at all
| | #8 | |||
| mad bad and very very old | Re: Overheating Sporting
If no hotness, then thermostat is the main culprit. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | |||
| | #9 | ||
| Re: Overheating Sporting Swapped the thermostat during the lunchbreak today and let it run on idle for some some 30-40 mins(I know, global warming yadayada..its cold in Sweden anyway) and it stayed at 90-100degrees. It still a little hot but I guess that's due to the fan not working, or atleast I think it's not working. Never seen or heard it move.. I'll try to locate the fan problem this weekend, anyone have any good ideas on "known fan failing reasons"?
| | #11 | ||
| Re: Overheating Sporting my sporting punto kept overheating...just on short trips too! i checked my radiator and it was cold - obviously the water wasnt going through it...there must have been a block! i flushed it out using a hose pipe and now it seems to be ok ![]() hope this helps!
| | #12 | ||
| Re: Overheating Sporting Hi there I had this problem about a week or so ago, the rad had frozen, the water in the header tank was hot and the heater was warm. The car did have anti-freeze in but obviously not enough as i drained it and put the proper mixture in and i have had no problems since. Cheers Nick
| Tags |
| overheating, radiator, thermostat |
| | custard | Cinquecento / Seicento | 72 | 1 Hour Ago 00:54 |
