The FIAT Forum
Old 16-02-2008   #1
Whiley's Avatar
Trader Rating: (0)
oil breather smoking and smoke when remove oil cap
any deffinative reasons this would be happening^^ im thinking rings are starting to wear or worse, have mayo in cap aswell though so a tad confused at the mo if its hg aswell any ideas?
Van Aaken High Boost Turbo Cinq In Caribean Orange, Highly Modded
Whiley is offline
Old 16-02-2008   #2
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Re: oil breather smoking and smoke when remove oil cap
Classically, rings, although it could be valve stem oil seals (or valve stems). Mayo? In the turbo car? Compression test asap.
Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes!
fingers99 is offline
Old 16-02-2008   #3
Whiley's Avatar
Trader Rating: (0)
aye mayo in tubby wubby forgot to mention breathers venting way too much aswell so i may be another one going down the new engine route
Whiley is offline
Old 16-02-2008   #4
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Is this the one you've just taken out of storage?
D
rallycinq is offline
Old 16-02-2008   #5
Whiley's Avatar
Trader Rating: (0)
aye
Whiley is offline
Old 16-02-2008   #6
rallycinq's Avatar
Trader Rating: (1)
OK, don't panic. Let it warm up fully in its own time then take it for a run. The engine will be full of condensation.
Change the oil and filter.
Review after several runs.
D
Old 16-02-2008   #7
fingers99's Avatar
Trader Rating: (1)
Have you changed the oil? If not, there is a chance that the old stuff has picked up moisture which the engine is trying to evaporate: the only place it can go is out the breather (unless you remove the cap).
Ha! Beaten by Rallycinq! (Again)
Old 16-02-2008   #8
I Need Beer
allanhelen's Avatar
Trader Rating: (0)
allanhelen has donated! United Kingdom
This cold weather is a bugger as well, my car hasn't used a drop of coolant in the last 1000 miles but you wouldn't believe the amount of water i'm getting out of catch tank especially when it's doing short runs (no mayo in the cap though) it can only be condensation.
VAD Hi Boost Turbo Cinq
None Fiats 3.2 V6 Cavalier, Peugeot 206 GTI 180 & JR Supercharged Mk2 Mazda MX5 1.8
allanhelen is offline
Do you smoke (cigarettes)? luvduvs Leisure Lounge 162 04-05-2007 14:16
