| headgasket hi i think my h/g has gone on my sei sporting,does anyone have a rough idea of how much a garage would charge to repair.cheers
| Wide arch Hormann Turbo | Re: headgasket Hi We do FIRE engine head gaskets for £275 all in including skim, new cambelt+tensioner, new head bolts, new oil+filter and new antifreeze. If anyone quotes much more than that walk away. Rich.
| | #4 | ||
| Re: headgasket hi,pulled oil filler cap off and white mayo substance in cap.can't see any oil in water tank. oil and water levels are still the same and car seems to be running fine,but dosen't always start on first turn off the key,were as it did before.cheers
| | #5 | ||
| mad bad and very very old | Re: headgasket OK, you can probably relax on the HG front. When you say doesn't start first time, is it turning over but not firing, or is it turning over and trying to fire? Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #6 | |||||
| Re: headgasket
if you think hg is ok ,what would cause the mayo in filler cap. cheers
| | #7 | ||
| Get a wriggle on! | Re: headgasket you can still get mayo in filler cap if you only use the car for short run, where it may not get the chance to get warm enough, its condensation probably, mixing with the oil.
__________________ | ||
| possible headgasket on panda bella. | partsman1978 | Panda (Classic) | 24 | 06-02-2008 13:55 |
| | cduuffo13 | Punto | 6 | 30-12-2006 02:57 |
| | sexyholly | Cinquecento / Seicento | 5 | 04-10-2006 10:21 |
| | Jack c | Punto | 4 | 22-03-2006 11:07 |
| headgasket woes | dmrtim | Panda (Classic) | 10 | 18-02-2006 21:41 |
