Thread Tools
Old 05-02-2008   #1
stuartp has donated!
problem with one headlight - full beam but no normal or dipped
haynes manual doesn't seem to help
anyone on here a bit technically minded who might have a clue why one of my car headlights works on full beam but not normal or dipped?
it's all one bulb as far as i can see and i have changed it for a new one to no avail
could it be that full beam is on a different fuse to normal?
but i looked at all the fuses and they seem ok
wtf can it be?
can't go to the garage for a headlight - that'd be a disgrace
ta
stuartp is offline Reply With Quote Quote
Old 05-02-2008   #2
arc
this is where i stand
arc has donated!
Re: problem with one headlight - full beam but no normal or dipped
full beam is a different fuse.
fuse F8 for RH dipped beam.
fuse F9 for LH dipped beam.
haynes, section 12.18
edit:
is the sidelight not working either? which headlight is faulty? is it the actual sidelight bulb not lighting, or just the dim dip bit not lighting up, and the side light bulb still works?
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 05-02-2008   #3
ta
it's the passenger side headlight
all other lights are working fine
got to admit those electrical drawings in the manual send my head spinning - can't make them out at all!
Old 05-02-2008   #4
Trader Rating: 5
fingers99 has donated!
Quote Originally Posted by stuartp View Post
ta
They're not the best! Try fuse 9 in the main fusebox next to the bonnet release.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 05-02-2008   #5
arc
arc has donated!
i already said that
if you press the button near the ignition switch and turn the key backward, do both front lights light up the same then?
it does just sound like the fuse, but saying the side light isnt coming on as well.. that's a different fuse (same one that does rear lights), they're only linked by the earthing point - which is also linked to the full beam.
soooooo, yeash. fuse F9.
Old 05-02-2008   #6
Quote Originally Posted by arc View Post
i already said that
not aware of a button near the ignition (nor that you could turn the key backwards)
i'll try that later
and i'll take another look at the fuses
cheers for your help
Old 06-02-2008   #7
all fuses look fine
all other lights checked and work fine
passenger side headlight doesn't come on with the button pressed and key turned backwards (what on earth is the function of that button?)
i can only conclude that either both bulbs i tried were faulty or more likely the connection to the bulb itself is faulty - i'll stop off at halfords on my way home tonight and buy another new one and test that
if it is the connection then aside from cleaning it i don't know what i can do to fix it other than take it to a garage
Old 06-02-2008   #8
Serbia
The function of that button(i "discovered" it myself about 6 months after i bought the car) is probably to keep the lights on after you exit the car so others can see it (noticed that you can remove the key after you turn it into that position? )
nmrmak is offline Reply With Quote Quote
Old 06-02-2008   #9
arc
arc has donated!
swap the fuse for the RH with the LH. test.
swap the bulb for the RH with the LH. test.
swap the sidelight bulb for the RH with the LH. test.
Old 06-02-2008   #10
Trader Rating: 5
Quote Originally Posted by nmrmak View Post
They're called "Parking Lights"!
M12 fund 20
Old 06-02-2008   #11
Serbia
They would drain your battery overnight
Old 06-02-2008   #12
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Not neccesarily. Its four 5 watt bulbs, so 20 watts total, therefore less than 1.66 amps. 8 hours overnight = 13.28 amps.
A good battery should cope with that.
D
Old 11-02-2008   #13
half sorted
went and got a new bulb (after trying two supposedly new ones that i had in my box of stuff) and i now have full and normal beam but for some strange reason i still don't have dipped on that side
weirdness
Old 11-02-2008   #14
Trader Rating: 5
Re: half sorted
weirdness
There are two elements in the big long bulb, dip and main beam. I think you're calling dip "normal". The parking/sidelight bulb is seperate (a smaller bulb). That may have gone, too.
M12 fund 20
Old 12-02-2008   #15
Re: half sorted
Quote Originally Posted by fingers99 View Post
by dipped beam i mean when you flick the light switch on the dashboard up one for when it's just getting dark - this is what i currently don't have on the passenger side
by normal beam i mean when you flick the light switch on the dashboard up twice (to the top) for driving at night - working fine now
by full beam i mean when you move the stalk up (or down - can't remember) for belting round country lanes - working
not sure what you mean by parking or side light (unless you mean the indicators)
I haven't taken the whole light housing out to be honest but it doesn't seem to have more than one bulb in there
Thread Tools
(T) how do you align headlight beam thefishdude Punto (Mk2/2b) 7 03-09-2006 21:06
(G) Full Beam turns headlights off klaus23 Punto (Mk2/2b) 4 18-01-2005 12:07
(T) Another, but slightly different, headlight problem jip Bravo / Brava 2 10-12-2004 20:00
(G) Mid-throttle injection problem in Lancia Y10 FatNote Panda (Classic) 26 30-07-2004 18:58
(T) Full Beam pjp Stilo 4 27-03-2004 03:30
