| Seicento 16v Starter Moter Q. HI all, As some of you may or may not be aware I have a highly modified 1242 16v in my Sei mpi sporting. I'm a little unsure about the correct starter motor to use. To my knowlege its currently on a stock 1108 mpi starter. Would it be wise to upgrade to a 1242 16v or 1368 16v starter as am sure have heard mentioned there are differences. Car starts on the button everytime when driven regular however, If it is left for 3 days plus takes a good 3-5 seconds to catch before firing up. (This isn't often for me but annoying). Has only done it since engine convo. Batt was new 18 months ago and alternator seems to be charing fine, runs consistently above 14 v with no aux systems on. Runs at no lower than 13.5 with full lights inc fog/full beam etc. Just seems odd, could be bad contacts, but seems like another issue to me! Just thinking correct starter motor would be a good place to start as I understand the 85 16v has a faster crank starting speed than 1108. Thanks in advance. J
| Re: Seicento 16v Starter Moter Q. I would expect the 16v starter to have a higher cranking ampage due to capacity and cr.
| | #3 | ||
| The Thrill of Driving.... | Re: Seicento 16v Starter Moter Q. I back up what CC1 has said, the higher compression of the 16V engines creates more pressure for the starter motor to turn engine over, so I would expect a higher power starter. Aaron.
__________________ ![]() 1992 Lancia integrale EVO1; 1995 Toyota Celica GT4 ST205; 2001 Seicento Abarth 1.4 16V 6speed (OK that one's Emma's) | ||
| | #4 | ||
| ' | Re: Seicento 16v Starter Moter Q. The 1108cc is 0.8Kw, the 1368cc is 1Kw, goodness knows what the 1242 16v is, 0.9 :P ?! Think dave the trike talks about them in his Supercharged Punto thread, but can't recall from the top of my head. I used to run the 0.8kw starter on mine 1242 without issue, but yours may be on the way out or it could be something else. It could even be to do with your very light flywheel not building up enough momentum. A 1368cc starter motor is a direct swap, I have a spare 0.8Kw if you want to borrow it to try. Could be a whole bunch of things though. Kristian
__________________ Black Seicento Sporting mk2 1242cc 16V conversion finished and removed! ![]() Megasquirt installed, a constant evolution 1368cc and 6 speed running great now ![]() My Members Motors thread ![]() | ||
| | #5 | ||
| Scandinavian Passion.... | Re: Seicento 16v Starter Moter Q. Is the engine turning over cleanly but not catching? I have a problem where the engine will just turn over cleanly for several seconds then burst into life or sound like it's caught and as soon as the starter is released the engine will stall. When it does this the fuel pressure is pulsing to, but not steady at, 45psi.
__________________ Daily Driver: Seicento Sporting, Dark Grey, MPI 1108cc 8v, stock externals Track Day: Seicento Sporting, Yellow, High Boost 1247cc 8v, Factory Abarth body kit Luxury Liner: Volvo V70 D5 Sport, Black, chipped & uprated intercooler, V70R body kit Last edited by StoneNewt; 04-02-2008 at 22:54. | ||
| | #6 | ||
| Re: Seicento 16v Starter Moter Q. Thanks for the replies. That would prob explain an aspect of it. Car is running a CR of around 11:1 similiar to the 1368 16v as opposed to the 1242 16v's 10.4:1 or there abouts to improve torque. What would be the better starter to go for 1368 or 1242 16v one? J
| | #7 | ||
| Re: Seicento 16v Starter Moter Q. Just seems odd starts on the button if driven daily, also short term ie. if I turn off to put fuel in, then start up. Even if I leave for like 3 days is normally fine. Surely if it was down to the flywheel it would be like this at all times. If anything it gets better the more the car is used. It got to the extent this morning (car had not been started for the whole week) where I had to crank it a few times and press the accelerator, then there was a little smoke (from left over fuel at a guess). Wasn't happy. Would like to get this sorted and have neglected the car loads the last months due to no time. I am also in need of cleaning / replacing the idle control valve as am not happy with it. Thanks for the offer re starter motor Kristian and for replies everyone.
| | #8 | ||
| ' | Re: Seicento 16v Starter Moter Q. If your getting a starter new, then the 1368cc no doubt. It's bound to be at least equal or more powerful than the 1242. //edit - you got an alarm etc? I was researching batteries, and they loose a lot of power in a few day, then kind of level out, due to drains on the battery. Even though it is new, maybe a higer capacity battery in the boot, or a red top battery for crazy high CCA could sort it. Good thing is, leave it a few days, when you would normally get the prob, and jump it witha second battery. No issues starting and you know where to look
__________________ Black Seicento Sporting mk2 1242cc 16V conversion finished and removed! ![]() Megasquirt installed, a constant evolution 1368cc and 6 speed running great now ![]() My Members Motors thread ![]() Last edited by kritip; 04-02-2008 at 23:07. | ||
| | #9 | ||
| Re: Seicento 16v Starter Moter Q. Lol anyone got an idea of the retail of one of the 1368 starter motors?
| | #10 | ||
| | #12 | ||
| | #13 | ||
| Re: Seicento 16v Starter Moter Q. Well if Kristian can do it on a 1368 then i'm sure the Sei batt will be up to the job. Looks like I could be looking around the £110 mark. Not bad really. But going to go mapping first as fuelling still far from perfect, check icv, contacts, charge etc. The if still at a loss will try new starter.
| | #14 | ||
| Re: Seicento 16v Starter Moter Q. If it turns over at the same speed after 3 days then it could be some thing else. Try turning the ignition on and off a few times to prime the fuel lines. Shouldn't realy de-pressurise but if it does then the pump could be on it's way out or fuel injector seat/s worn.
| | #15 | ||
| Re: Seicento 16v Starter Moter Q. Brand new 3 bar pump inc. sender went in back in November so should be very good. It definately seems to crank slower when it is left for longer. And naturally the more time it is cranked for the more the battery voltage starts to drop on cranking.
| | FiatStiloJTD | Punto | 543 | 06-06-2008 17:15 |
| Help with.... | Dobby | Leisure Lounge | 51 | 02-11-2007 17:56 |
