| | Thread Tools | Search this Thread |
| are they marked in anyway?
| The Little Blue Tractor | Re: how do i know which of the four wheel bolts holds my wheel trim on?
__________________ AJ x ------------------Fiat Cinquecento 0.9 = 2007-2008 Seat Arosa 1.4 = 2008 Last edited by _AJ_; 31-01-2008 at 14:17. | ||
| | #3 | ||
| Re: how do i know which of the four wheel bolts holds my wheel trim on? ya lie? all of them??.. wat kind of a knob end thought that wud be a good idea?.. sum dope at the garage put them on the wrung way round so i cant get at the valve. gotta take the whole wheel off now. *astad
| | #4 | ||
| mad bad and very very old | Re: how do i know which of the four wheel bolts holds my wheel trim on? Look closely at the bolt holes in the trim. two you can see through, two you can't. Its the ones you can't see through that you undo. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #5 | ||
__________________ AJ x ------------------Fiat Cinquecento 0.9 = 2007-2008 Seat Arosa 1.4 = 2008 | ||
| | #6 | ||
| Fehler in alle Teilen | Re: how do i know which of the four wheel bolts holds my wheel trim on?
| | #7 | |||
Cheers D
__________________ If it has pistons or tits, its going to be expensive. | |||
| | #8 | ||
| Re: how do i know which of the four wheel bolts holds my wheel trim on? hm.. mehthinks fivehundred and rallycinq both make luv to mans bottoms
| | #9 | ||
| Re: how do i know which of the four wheel bolts holds my wheel trim on? I wouldnt say that about rallycinq. He might come in very handy for you one day, well not anymore as you say he "makes luv to mans bottom" I know he's helped me out a fair bit with info for prepping me cinq and helped alot of other members.Just be carefull on what you say and who you say it to, and your a newbe
__________________ 16v cinq with ITB's ![]() Last edited by Brooky; 01-02-2008 at 01:31. | |||
| | #10 | ||
| Re: how do i know which of the four wheel bolts holds my wheel trim on? sensitive people !.. just playin. apologies![]() can i buy your wheels 5hundred? i can collect if u still have them. are/were u using spacers on them? ta. adam
| | #11 | ||
| | Reaver23 | Punto | 19 | 22-08-2008 19:06 |
| | mqsash | Uno | 9 | 09-01-2007 20:09 |
| Wheel Trim advice | PandaPerson | Panda (New) | 2 | 20-03-2005 19:55 |
| Wheel Trim Panda Problem :( | PandaPerson | Lets Talk FIAT | 0 | 18-03-2005 22:15 |
