| Cinq petrol leak... I have a 96 P Cinquecento S, which I have been assured has had a replacement petrol tank after the recall. However, I have noticed a strong smell of petrol inside the car that seems to be coming from a small hole to the lower right hand side of the petrol cap - in the plastic next to the cap itself at about the 5 o'clock position. The hole almost looks like a small drill hole in the plastic. I'm not 100% sure that this is the source of the leak but petrol is certainly coming out of the tank at the cap somewhere. The smell is strongest after a sharp left turn with a half full tank (I can't fill it up completely or the smell is over-powering) when I guess the petrol splashes up to the cap . Has anyone else had this problem? Does anyone know the exact reason for the replacement of petrol tanks on recall by Fiat? And could you recommend a better solution than the blob of blu-tac covering the hole at the minute!! Thanks. G
| i'd use chewing gum [:o] but i'm sure pete will come up with something better ;) SEI POWER
| | #3 | ||
| The fuel tanks were replaced under recall due to rusting, apparently some rotted quite badly at the top half. About your petrol leak - check that the rubber seal on the cap itself hasn't perished, it's not uncommon. Good luck, and welcome to the forum BTW!! Pete. Cinq sporting 1242cc http://mysite.freeserve.com/close_to_cracking_up/ http://autos.groups.yahoo.com/group/Cinqs_and_Seis/ http://www.clubcento.co.uk/
| | #4 | ||
| Re: Cinq petrol leak... I have the same car, a yellow Cinq sporting P reg, and the same small hole and, yes, the same smell. I'm also guzzling petrol like a Range Rover. Help, please. But I never really noticed this problem until after I had the clutch cable replaced. Could the mechanic have nudged something? Could my missing air bleeder pipe from the engine (if it's called that) be the problem instead?
| | #5 | ||
| RIP L181 VBB | Re: Cinq petrol leak... Chances are the same thing has happened as above. Explore these routes mentioned above first
__________________ ![]() 2001 Modded Sei Sporting - GONE!! 1998 Ford Mondeo 1.8LX - P/X'ed 2002 02 Ford Focus 1.6 Zetec w/ Climate Pack! | ||
| | #6 | ||
| Re: Cinq petrol leak... Hi, The small hole at the 5 o clock position is the drain hole (for rain water and spilled fuel), so I doubt if thats your problem, I agree with the above, check your fuel cap seal, I had a halfrauds cap on my 900s when bought, but it leaked like f*ck, fiat fuel caps are only about £8 +vat iirc. If you are sure the cap is good, then I would check out the emission control system, the tank should be kept under a slight vaccum by the engine to prevent fuel vapour escaping, this is controlled by a solenoid on top of the carbon evap can, which is connected via a long pipe to a 3 way safety valve on top of the fuel tank, this valve can sometimes stick, blowing air through will normally cure the problem, but be carefull if you use a high pressure air line as it can blow the pipes off the valve. Hope I havent funcused you too much Thanks Paul T
| Lower Petrol Prices! | badboyz016 | Leisure Lounge | 14 | 27-05-2004 09:58 |
| Cheaper petrol? Will it work? | bazd123 | Leisure Lounge | 3 | 26-05-2004 23:49 |
| | Zed One | Cinquecento / Seicento | 3 | 31-01-2004 19:52 |
| | Sando | Cinquecento / Seicento | 7 | 01-12-2003 19:01 |
