- Feb 16, 2005
- 5,983
- 988
sensors are not an issue. I ran an entire 1.2 16v engine with all its sensors, injectors etc on a 1.1 8v mpi ecu with no issues
i will seee how much it cost, a trottle from a 1.2 16v. i have tryed to make my standard trottle langer but failed because i cant get the valve out. totale dammaged the screws...
but this is very intresting, i've allready got a 271 cam and open exhaust...
can i put bigger injectors to? what size? (got a 1.1mpi sei) and do i need to put a larger fuelpomp to??
You might avoid a lot of pain by simply using one of the newer super epoxies to glue the flange from the new TB to the end of the old one, after having opened out the hole.
This is what I plan to do to get a K Series TB to fit the Idea/Stilo 1.4 16v inlet manifold (lots of roughening up with a mini die grinder first).
Because of the way the plastic Mpi inlet manifold upper moulding is designed, you are restricted to about a 40/42mm TB if you make the hole bigger. You may get bigger if you remove the mounting flange completely and epoxy on another?
MF59 Mpi Ecu's do not like too much change from a standard setup. but the 6F? I know nothing of.
Guys,does this really worth?Will i have to Remap?
My Sei Mpi is slightly tuned right now with custom headers-exhaust,K&N filter and now i have a Novitec 998 Camshaft in my hands which i don't know if it's the same as Punto 866(Please let me know)...
If it does worth,i would like to have some detailed instructions and pictures of it ASAP!!!
