| TruBlu | Blu's Turbo Re-shell Thread Hello peeps.. Thought i'd start a proper thread for this project.. Anyhow, heres a pic of the new shell, kindly provided free of charge by pranksta, thankyou very much young man! Its a 899sx, Correct me if i'm wrong but being an sx i don't need to swap the looms over do I? Although its look pretty sorry for itself at the mo, the shell is in good shape. 1 tiny door dink on passenger side, and evidence of filler on the tailgate but looks good apart from the paint which is no biggy as its going to be resprayed (eventually). Currently its like a swimming pool inside due to blocked drain-holes on the sunroof, no rear lights so water getting in there too and the rear windows are not really held on by anything.. So i need to get that sorted, i'm using parts from the old car to secure the windows on so all i've been doing so far is stripping out the inside of the old car so that the bits don't get damaged by water.. Got all the seats out, carpet, headliner, rear speakers and amp out today. Tomorrow i will be sorting the windows and putting the 899 rear lenses back on to get it water tight (need new rear lenses really having had a look at mine, mounts broke on one and the other was cracked and full of water). Dunno what to do about the drain-holes as of yet as can't for the life of me find the bottom of them but the roof is gaffer taped up and has some plastic of it for now. Thats it for now, i'll keep updating this thread as i go though, and i'll try remember to take pics as i go as well.
__________________ ![]() | ||
| The Thrill of Driving.... | Re: Blu's Turbo Re-shell Thread rallycinq or even robrandomsruisers are probably best to speak to as they have both done 899-FIRE conversions, but AFAIK yes you need the loom, plus as its a turbo you will need to change over the full ECU set up as well, so that means all the locks have to be changed as well to make sure immobiliser works OK, I found when we built the Imola out of the twisted red car following the accident, that I had to effectively change everything over, TBH it was a PITA and when it came to doing Emma's turbo, we very quickly agreed to rebuild the turbo in its original shell than swap everything over to her original Cinq, as making that a tidy car was much less effort than swapping everything over again, and that was with prior knowledge. Good luck with it though, its a learning process, label, label and label again everything you remove with regards to teh loom, MF2, fuel cut defender, take pictures of stuff before and during removal, making putting it all together so much easier with visual referance to everything. Aaron.
__________________ ![]() 1992 Lancia integrale EVO1; 1995 Toyota Celica GT4 ST205; 2001 Seicento Abarth 1.4 16V 6speed (OK that one's Emma's) | ||
| | #3 | ||
| Re: Blu's Turbo Re-shell Thread get some welding rods and poke about in the drainage holes probably full of leaves i expect lol
__________________ ![]() Van Aaken High Boost Turbo Cinq In Caribean Orange, Highly Modded | |||
| | #4 | ||
| umop apisdn | Re: Blu's Turbo Re-shell Thread What colour you going for?
__________________ Your sister is hot, but your mum does that thing with her tongue | ||
| | #5 | |||||||||
| TruBlu | Re: Blu's Turbo Re-shell Thread
__________________ ![]() Last edited by blu73; 14-01-2008 at 21:00. | |||||||||
| | #6 | ||||||
| Classic Uno Obsessive | Re: Blu's Turbo Re-shell Thread SlinkyCinqi has also done an 899 to 1242 FIRE conversion so he will know all about wiring looms and stuff. I seem to remember that you might get away with just changing the engine bay wiring loom and and everything from the dashboard forewards. You might be able to simple unplug the engine and dashboard loom from the fuesbox if it's anything like a Uno. Then again, that doesn't leave much left so you might as well change it all if you're stripping and transferring from one shell to another. As for the sunroof drain tubes, how about pumping compressed air through them? That might shift the blockages ![]()
Might not be good for the wallet initially but it will work out cheaper in the long run.
| | #7 | ||||||
__________________ ![]() | ||||||
| | #8 | ||
| mad bad and very very old | Re: Blu's Turbo Re-shell Thread I changed the whole loom, but you should be able to get away with changing just the front. However the front part is the more difficult bit to do. Make use of your digicam and photo every joint, once in place and a second time showing them split. The more pictures the better. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #9 | ||
| Re: Blu's Turbo Re-shell Thread just paint the engine bay when engines dropped is exactly what i did
| | #10 | ||
| TruBlu | Re: Blu's Turbo Re-shell Thread Not alot to report but as i'm rarely online atm.. Rear lenses on and new windows on the back of new car, hardly leaking at all now lol.. Just waiting for to stop pissing down with rain so i can sort the roof. Other than that headunit, amp, rear speakers and all related wiring outta old car. thats it. no pics as they'd be boring and show the lack of progress i've made lol Hopefully stop raining soon and i can make some real progress
__________________ ![]() Last edited by blu73; 17-01-2008 at 12:01. | ||
| | #12 | ||
| TruBlu | Re: Blu's Turbo Re-shell Thread update: Roof is not leaking anymore Changed rear window rubbers over and ones fixed, 1 is still leaking, just need to get it sat right though (was getting dark). So car should be water tight tomorrow.Also i've swapped the bootlids over. This is because even though my old one has a little dent, the red one has blatantly been repaired at some point and i intend to do some smoothing and i know mine isn't hiding anything nasty under the paint, will fix the dent when smoothing rest of it. I'm a bit unsure really what to do next now. With the bad weather at the moment i was intending to do the interior next but thinking perhaps i should wait till after the wiring is all sorted as access is gonna be alot easier with it all out. So i guess i start taking out the engine now. Then the wiring... sound like the right order to you? (think i'm just gonna swap all the wiring over now, should be easier than splicing them together i should think. (will try upload some pics 2moro but it looks much the same atm tbh) edit: on the drainhole front, if anyone ever has this problem in the future, if you take the headliner out the whole job become less tiresome, you can tkae the rubber hoses off easy peasy, then you can clear the holes on the roof from behind (much easier!!) and get the hose cleared off the car and re-attach. Just incase someones having the same problem at the mo
__________________ ![]() Last edited by blu73; 23-01-2008 at 19:44. | ||
| | #14 | ||
| TruBlu | Re: Blu's Turbo Re-shell Thread okies, thats on the cards for tomorrow then, although i gotta measure up my plot of land 1st thing 2moro as i'm putting in for planning permission to build a house next to mine.. But i shall start disconnecting stuff afterwards (and when i've found some more axle stands to borrow, mine are holding up the old car at the mo so need some more.)
| | #15 | ||
| TruBlu | Re: Blu's Turbo Re-shell Thread Right just a quick one as theres not much to tell atm, Stole some axle stands from my uncle and engine is just about ready to drop outta new shell, just driveshafts remain then it can come out.. Not made any more progress than that as i don't fancy doing it on my own without a engine hoist and all my free workers are on holiday at the mo but are back tonight. Progress is slow atm but its progress nonetheless. Its not actually raining at the mo so might go get some pics and upload later not that it looks much different.
| Tags |
| cinq, re shell, turbo |
| | beau | Uno | 142 | 21-09-2008 21:19 |
| | 1986Uno45S | Uno | 31 | 01-03-2008 09:58 |
| | J333EVO | Cinquecento / Seicento | 28 | 08-11-2005 00:55 |
| Panda turbo parts list(for those that care) | smokeme | Panda (Classic) | 1 | 19-08-2004 19:22 |
