today i tried to change the drive shaft gaiters on my cinq. following the haines manual i used a ball joint seperator to split the joint leaving the nut on the end to protect the threads. but now the fall joint is free i cant undo the nut or tighten it back up, i think the threads might be abit shagged. ive tried popping the joint back into place with g-clamps and everything. has anyone got an ideas or am i going to have to cut the threads and fork our for a new track rod end?
picture if it helps
picture if it helps
