| Hub nut size? Hi all, Just about to change out one of my diveshaft boots. On the in board side. Im ok with the procedure having done it multiple times on a peugeot 205. I was just wondering what size the hub nut is before i go out and buy the wrong sized socket. I know its probably in the haynes manual somewhere, but i thought id aks on here before scouring through it. Cheers.
| mad bad and very very old | Re: Hub nut size? You don't have to undo the hub nut to get the shaft out. Remove the top of the two front upright retaining bolts and loosen the lower one. You can then tilt the upright enough to release the shaft from the cup. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #3 | ||
| Re: Hub nut size? As stated you don't need to undo the hub nut to change the gaters, but if you want to mess about with all that the front is 32mm.
__________________ ![]() | |||
| | #4 | ||
| Re: Hub nut size? cheers guys. that should make it alot simpler.
| | #5 | ||
| | #6 | ||
| ' | Re: Hub nut size? Ah, I wondered why you knew what RC said, off the top of your head GoBe ![]() Just to mention, we did this today on mine....they are a bit difficult to release from the cups but with a bit of gentle persuasion, do come out, and it saves a lot of hassle Kristian
__________________ Black Seicento Sporting mk2 1242cc 16V conversion finished and removed! ![]() Megasquirt installed, a constant evolution 1368cc and 6 speed running great now ![]() My Members Motors thread ![]() | ||
| | matty_oakley | Punto | 4 | 06-04-2007 01:24 |
| | roseyp | Bravo / Brava | 8 | 05-01-2007 11:42 |
| | dazzo666 | Bravo / Brava | 1 | 09-10-2006 21:55 |
| anyone wants to upload vids.... | charlieboy | Leisure Lounge | 0 | 12-01-2006 17:59 |
| | catchy | Punto | 0 | 07-12-2005 11:00 |
