The FIAT Forum
Old 02-01-2008   #1
Trader Rating: (0)
Ireland
Unhappy Lost my only key
I lost the only key for my cinqucento from 96.
I am very bad with cars and do not wish to get all hands on.. if at all possible.
It was a blue key. And I never received any other key. Car is working fine.
But we are locked out.
What are my possibilities??
Everything might be helpful.
Duruta is offline
Old 02-01-2008   #2
"The Black Diamond"
SlinkyCinqi's Avatar
Trader Rating: (0)
SlinkyCinqi has donated! United Kingdom
Re: Lost my only key
this will need to be moved, as it's not a guide!
As for your situation, is the car a 900 or a sporting?
Lenny
SlinkyCinqi is offline
Old 02-01-2008   #3
Trader Rating: (0)
Ireland
I have absolutely no idea .. called a few fiat dealers today .. and the totalt cost Is going to be more than 1000 Euro : More than the car is worth
Duruta is offline
Old 02-01-2008   #4
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
look on the back of the car and it will tell you the model
or look here
http://www.fiatforum.com/cinquecento...ts-my-car.html
it wont cost 1000 euros but a little info will help us to help you!
eg
http://cgi.ebay.co.uk/Fiat-Cinquecen...sid=p1638.m118
custard is offline
Old 02-01-2008   #5
Banned
Trader Rating: (2)
Bushboy has donated!
What I would personally do.
Goto a scrap yard that has a cinq of the same model. Buy the following bits
  • 1x rear quater window
  • 2x door locks, 1x boot lock, 1x ignition barrel lock FROM THE SAME CAR WITH KEY.
  • 1x ECU + code box from the same car as locks
Go home. Smash the rear quater, unlock the car, fit new window, then set about changing the barrels in the locks and the ecu. Everything will now work off the new key. Get it copied!
Alternativly you can keep your current ECU but you will need to buy a mchrich performance chip that disables the imobiliser. Probably cost about the same as a second hand ECU anyway.
Replacing the lock barrels is easy enough. boot is simply a few bolts. door are a little trickier as you have to remove the interior door panels to get at the rear of the handle and then remove that etc. Not a bad job though. Ignition is a little trickier still but im sure someone will be able to tell you exactly how to swap it. Ive never done it.
Other than that, see if a good lock smiths can make you a new key from the lock barrel itself. Then get a decoded ecu or a mckrich chip that disables the imobiliser, that way you wont have to change any of the locks but it might cost alot at the lock smiths. It wont cost you anywhere near 1000 euros though. More like 100, even with buying all of the new locks and ecu.
Bushboy is offline
Old 02-01-2008   #6
Trader Rating: (2)
ycming has donated! United Kingdom
would be a different case if it is a 899, then it would be much easier, as there are no red or blue key and no codes.
Yes a lock smith will able to do you another key, as i done it to my honda, cost £50 quid to get a key made up from the barrels.
Wanted : Nothing at the moment
ycming is offline
Old 02-01-2008   #7
mr500's Avatar
Trader Rating: (0)
IIRC you can take door handles off with inner panel on. Tricky but do-able...
I can resist everything except temptation...
mr500 is offline
Old 02-01-2008   #8
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
chaos has donated! United Kingdom
That's not right - it goes off age not trim level. The CODE system was introduced across the range in 1995 IIRC.
Chaos - Life wouldn't be the same without it.
Cinq parts clearout!
chaos is offline
Old 02-01-2008   #9
RIP L181 VBB
AppleSei's Avatar
Trader Rating: (4)
AppleSei has donated! United Kingdom
older cinqs are black keys only IIRC certainly no red key malarky
2001 Modded Sei Sporting - GONE!!
1998 Ford Mondeo 1.8LX - P/X'ed
2002 02 Ford Focus 1.6 Zetec w/ Climate Pack!
AppleSei is offline
Old 02-01-2008   #10
Trader Rating: (2)
sorry my mistake .
ycming is offline
Old 03-01-2008   #11
TruBlu
blu73's Avatar
Trader Rating: (0)
blu73 has donated! United Kingdom
Yep, did my old cinq this way, didn't find that hard at all really..
blu73 is offline
Old 03-01-2008   #12
Trader Rating: (2)
hmm.. may be get an old 899 ecu and barrels, then there would be no key code stuff needed??
Would that work ?
ycming is offline
Tags
key, lost keys
(T) Bravo red key problem reddy4bed Bravo / Brava 22 23-01-2008 10:24
(T) 55S - Lost the red key colinM Punto 12 29-10-2007 19:07
(T) Lost only key - Punto 98 pieterlouw Punto 3 17-09-2005 15:01
Help! LOST RED KEY FIAT BRAVA JTH Lets Talk FIAT 3 15-03-2005 21:49
(T) 55S - Lost the red key colinM Punto 1 13-06-2003 23:23
