| car is 97 cinq sx which i picked up very cheap a few months ago..been doing some b/work and gen bits myself but now have a prob.. went for a spin this morn and after a few miles cinq started to lose power and gradually ground to a halt and coolant seemed to have disappeared also but upon refilling with trusty bottle of water it started to diss again but no external sign of leakage..managed to get cinq home but everytime we slowed down she cut out.. lost two litres of coolant in a 3 mile trip but no idea where..also now have excessive smoke out tailpipe and have smoke coming out exhaust joints underneath.. car was/is to be used to help my teenage daughter to drive later this year..main family car is a 4wd 8 seater any help please..
| mad bad and very very old | Re: erratic idle..coolant loss..power loss You need to find where the water is going. Make sure you bleed it when refilling, then run it until you see the water coming out. If it doesn't then its possibly the headgasket. If the headgasket has gone its more than likely there is fault somewhere, possibly the cooling fan motor, or radiator itself. Its a fairly straight forward wee engine to work on, Couple of hours should see it stripped, then off to the machine shop for a head skim (not you, the car's head), new gasket set and couple of hours to get it back together again. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| The following user says "Thank You!" to rallycinq for this useful post: | ||
gortan (29-12-2007) | ||
| | #4 | |||||
| | #5 | ||
| Clubcento Member | Re: erratic idle..coolant loss..power loss Have a look in your coolant bottle and smell for exhaust and look for an oily film. More than likely it's the other way around with water getting into the engine (if it is indeed a HG) in which case there should be white gunk in the oil. It might also be a rotten radiator, dodgy water pump or simply a leaking/split pipe. Go for a drive to run it up to temperature and park it up with some cardboard underneath to see where it could be dripping from.
| | klo | Bravo / Brava | 5 | 23-05-2007 09:11 |
| | griessgm | Palio | 4 | 04-04-2007 15:50 |
| | Tangerinedreamer | Bravo / Brava | 2 | 19-04-2004 05:55 |
| | pokerface | Cinquecento / Seicento | 3 | 14-03-2004 02:11 |
