The FIAT Forum
Old 28-12-2007   #1
Trader Rating: (0)
Need Help With Rear Wheel Bearings!!
Hi all,
i have recently noticed my rear wheel bearings are going and was wondering is this a job i can do myself or are the bearings pressed. Any Ideas?
colinvansmith is offline
Old 28-12-2007   #2
Funny saying here
jamie86's Avatar
Trader Rating: (1)
jamie86 has donated! United Kingdom
Re: Need Help With Rear Wheel Bearings!!
The bearings are nice and easy to do
Unfortunately it does mean replacing the whole hub but that makes it even easier..
Get yourself on www.shop4parts.co.uk (or local fiat dealer) for this:
Rear Hub Complete
All Models
Part Number: S4P635
Manufacturer: European
Listed Price: £44.88
Our Price: £31.42
You Save: £13.46 (30%)
Please note that All Prices Exclude VAT.
Then remove wheel undo hubnut (possibly at 32mm but check ) You will prob need a breaker bar or torque wrench...
Remove old hub replace with new hub.. the do up using NEW hubnut upto the correct torque setting.. I also tend to use a punch to knock the edge of the nut in as well
HTH
Jamie
Originally Posted by A wise person
Mini invented the giant killer, VW started the genre, Ford & Vauxhall Desecrated it, but the Peugeot 205 GTi was undoubtedly the king of the breed.
jamie86 is offline
Old 28-12-2007   #3
Brooky's Avatar
Trader Rating: (1)
I did this job...start to finish in 10mins
Will take longer if you dont have a good tool to remove the hub nut, or if the inner race is seized to the axle
16v cinq with ITB's
Brooky is offline
Old 28-12-2007   #4
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Yup, thats about right. I did both of mine in half an hour, but i did have to take the calipers off.
D
rallycinq is offline
Old 29-12-2007   #5
Trader Rating: (0)
nice one thanks folks
Old 29-12-2007   #6
Italians do it better :P
Trader Rating: (1)
Alfie has donated! Italy
if you havent got a pulling tool to remove the hub, after you take off the drum and hub nut whilst jacked up put the wheel back on with a couple of wheel nuts diagonally loosely then you can give the wheel a good yank till it comes off.
2000 X Seicento Sporting, Yellow 1108, 2004 54 Punto Van, White 1.3 16v MultiJet
muore la pecora muore l'agnello muore la gente piena di guai... ma i ROMPI COGLIONI non muoiono mai!
Originally Posted by binki
i had a AppleSei once worse hump i ever had
Alfie is offline
Old 29-12-2007   #7
TruBlu
blu73's Avatar
Trader Rating: (0)
blu73 has donated! United Kingdom
yep, simple job, took me 15mins each without a haynes and having done one.. You'll be alright mate
blu73 is offline
Old 30-12-2007   #8
Trader Rating: (0)
Even i have done this, really easys
darkitchy is offline
Old 30-12-2007   #9
Get a wriggle on!
levemir's Avatar
Trader Rating: (0)
levemir has donated! United Kingdom
Theres a guide on this job, when i did mine the hub just slid off the shaft, I was expecting it to be hard to do, hardest part is undoing the hub nut, make sure the car is very secure beforehand, I used an old torque wrench to undo it.
levemir is offline
Old 30-12-2007   #10
Trader Rating: (3)
My personal weapon of choice is a 1000mm or 1200mm breaker bar, relatively expensive to buy but very useful for this kind of thing. I'd also use an impact socket rather than a normal socket for this job.
GoBe is offline
Old 30-12-2007   #11
Principality Retained :)
Trader Rating: (3)
arseofbox has donated! United Kingdom
18"/450mm Breaker bar and 1m length of 40mmx40mmx1mm square stock FTW
Give that some aggro and it comes off easily. Does get rather scary when the breaker bar starts bending elastically though.
arseofbox is offline
Old 30-12-2007   #12
Brooky's Avatar
Trader Rating: (1)
what about when the end snaps offsome are only held in with a bolt or pin,they'll go before the bar snaps seen it happen when using scaffolding tubes, the guy always goes flying
16v cinq with ITB's
Brooky is offline
Old 30-12-2007   #13
rallycinq's Avatar
Trader Rating: (1)
That's cos they is doing it all wrong. Once the breaker bar starts to bend, just hold it at that position. You have applied the maximum torque. Eventually the nut or bolt will start to turn.
D
(T) Replacing front wheel bearings? AIJ29 Cinquecento / Seicento 2 31-10-2005 21:04
(T) Knocking noise from rear wheel dobson2k Bravo / Brava 0 14-09-2005 12:12
(S) Updated price list 21/04/2004 Body Stylist Punto 30 09-04-2005 17:02
(G) Rear Wheel Bearings Lifetime MotorWorldChink Cinquecento / Seicento 7 13-10-2004 20:34
