| revs hi,what rpms should a sei sport idle at when warm,mines at 1000 but it seems a bit fast is this right?cheers
| ' | Re: revs I'd say its too high. 850 ish is more like it. I'd imagine you have some kind of small vacuum leak somewhere. Kristian
__________________ Black Seicento Sporting mk2 1242cc 16V conversion finished and removed! ![]() Megasquirt installed, a constant evolution 1368cc and 6 speed running great now ![]() My Members Motors thread ![]() | ||
| | #4 | ||
| custodian of imola blue | Re: revs Too high (1000, that is). Could be that the throttle is set wrong, small air leak (possibly from the servo vacuum take off). If it hunts, suspect the MAP sensor or the pipe thereto.
| | #5 | ||
| Re: revs cheers for info guys, have checked for leaks in vacuum pipes but can't find any. when i pulled the hose off that joins the map sensor to the engine the revs dropped but the idling was rough.does this mean the map sensor is ok,also there is a carb can in the middle of this hose,could this cause high revs.cheers
| | Thatcher | Bravo / Brava | 2 | 09-07-2007 15:11 |
| | paultheton1000 | Punto | 8 | 11-12-2006 14:23 |
| | stilo-driver | Stilo | 2 | 27-08-2006 11:38 |
| | The Ugly Duckling | Cinquecento / Seicento | 3 | 26-07-2005 21:44 |
| | plasterman | Punto | 0 | 14-07-2005 09:17 |
